2 members (Peggy M, panic),
89
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2016 Posts: 26 'Bolter | | 'Bolter Joined: May 2016 Posts: 26 | Working on a 49 AD with a 216. Not worried about originality just driving. Any options for a voltage regulator (tractor, car.... ) that would work with the original generator? | | | | | Joined: Sep 2010 Posts: 2,306 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,306 | Rock auto has a replacement 62.00. | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | There are two kinds of voltage regulators for stovebolt trucks- - - -"Delco-Remy" and "Wrong!" Ebay usually has a good variety of used 6V GM regulators, and a few new ones if your budget can take the hit. Don't necessarily limit your search to Chevy- - - -Pontiac, Buick, Olds and Cadillac will probably work, as long as the item is 6V Negative ground. 6V GMC regulators will be Positive ground, and might not work as well as one with the right ground polarity.
Just checked- - - -there are at least 25 "new old stock" Delco-Remy 6V regulators on Ebay today, plus a large number of used ones. It would be hard to GIVE me any brand of regulator other than Delco for a GM product, based on 60+ years of making a living in the automotive trade. Jerry
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Never noticed this before. Don't know why it can't be wired to ammeter as the note says. ClickThis may be a good option for you. Otherwise, Classic Trucks is where you can get original type parts. They have the VR. Rockauto (kevinski) has a much BETTER Warranty and price. Theirs is a Wells unit, not Chinese. Well known name. Mfg'ed. USA and Mexico.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | I have a nearly new one sitting on a shelf. Would recommend just doing a conversion to a 12 volt alternator. I also ran the new alternator through the ammeter to the battery.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Nov 1995 Posts: 5,714 62401 | | 62401 Joined: Nov 1995 Posts: 5,714 | Speaking of the 12V conversion ... doesn't someone make a 12v alternator that looks like a generator?
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | PowerMaster Alternator $419 PowerGen Alternator $441 ($419-$469 from SpeedWay Motors) They may be the same generator? Gener-Nator$1,000 - much more expensive, but it looks just like your old generator (they use your old generator) | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The original Delco regulators are easier to adjust then the aftermarket replacements. They have a screw adjustment which is more accurate then the bend-a-tab type on the others. If this is a driver I too would change over to an alternator & 12 volts. The alt. puts out a lot more charge at idle & is more dependable. If you use a 42-55 amp. alt. you can run it through the stock ammeter. Higher amps should not.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | The entire design concept of an alternator demands a short, large diameter housing, so the long skinny ones that resemble generators are horribly inefficient. They're also outrageously expensive.
Higher amp alternators just need a shunt to bypass most of the current around the ammeter, which effectively turns the ammeter into a charge/discharge indicator. No problem, as dash-mounted ammeters have always been notoriously inaccurate, even when the vehicles were brand new. Jerry
| | | | | Joined: Nov 1995 Posts: 5,714 62401 | | 62401 Joined: Nov 1995 Posts: 5,714 | Alrighty ... Settles THAT, then.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you want an alternator that looks like a generator, those generator-looking alternators should work OK.
Odder "upgrades"/conversions are posted here all the time.
If anyone has used one of those generator-looking-alternators, please post your experiences.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | $400, WOW. I think the best options are a NEW or rebuilt Delco 10si 12V alternator 65A $40 or a NEW or rebuilt 1955.2 and up Delco 235, 283 V8 12V generator. looks like an AD, 30A $72.
PS: Tim, I think John has tongue in cheek....or could be a ceegar.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | 6v alternator positive or negative ground with choice of pulley width on ebay: $135. I'm too cheap to stay with high priced generator stuff that none of the present day people know how to test or work on and you said originality doesn't matter so it offers a choice. Also like alternator high output at low rpm.
Evan
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | 6v alternator positive or negative ground with choice of pulley width on ebay: $135. I'm too cheap to stay with high priced generator stuff that none of the present day people know how to test or work on and you said originality doesn't matter so it offers a choice. Also like alternator high output at low rpm. i think lots of folks are coming around to that understanding. 6V and generators and voltage regulators and no fuses is just a little too much nostalgia. Doesn't hurt the look or feel or value to upgrade there.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | 216 wny Mike E is right If you can make (or buy) a 1-wire alternator and install is best.Then bolt your gen andarm wires together at the regulator field wire not used. Then change battery and bulbs , resistor on gas gauge,12volt coil, that 12v will really whip it over ! Your wires will be plenty big, too! One thing I have learned over years is to use an alternator with more turns of wire on the rotor because it will prime easier. My delcotron teacher (An old guy) would grab a rotorand stick his thumb in there and touch the wire on the rotor and say that will prime better. Also a smaller pully helps too ! Good Luck HEI too | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | John Any idea why my posts disappear then reappear or never appear again ??? | | |
