| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 74 'Bolter | | 'Bolter Joined: May 2005 Posts: 74 | Looking to get a 283 rebuilt for a truck project, any recommendations for a shop in NC or VA are appreciated. | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | There's nothing particulatry mysterious about a 283, other than the fact that the newest ones are over 50 years old, and finding one that hasn't been rebuilt a couple of times already is going to be difficult. Are you looking for a "numbers-correct" restoration, or just a reliable daily driver? Finding a set of 58 CC combustion chamber 305 cylinder heads from the late 1970's or early 80's will be a lot simpler than locating rebuildable 283 heads, and they're a bolt-on swap that will give you the correct compression ratio. Jerry
| | | | | Joined: May 2005 Posts: 74 'Bolter | | 'Bolter Joined: May 2005 Posts: 74 | Thanks for the reply. Definitely not a correct restoration, this will be going in a 52 International L132 to make it a driver. Will likely pair it with a sm465 and a 14 bolt rear end. | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | I'd suggest finding a 305, then. It's got 1/2" more stroke, and a lot more torque than a 283. The only way to do truck stuff with a 283 is to run a very low gear ratio and keep it wound up all the time. There's also a bunch more 305's out there than 283's, and if you happen to have a correct engine number for a restorer to use, your engine will be worth a big chunk of pocket change, regardless of what condirion it's in at the moment. Jerry
| | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | Have you considered an LS swap? rather than an old sbc?
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | What about a 345 or 392 and 5 speed?
Ed
| | | | | Joined: May 2005 Posts: 74 'Bolter | | 'Bolter Joined: May 2005 Posts: 74 | I already have the 283 and it does run and I know it won't be a powerhouse. My thoughts were if I don't use the 283 then I'd go with a 350 or a 383 stroker. How does the cost of the LS swap compare to the sbc? What manual trans would work? This truck will be hauling 2-3 tons. | | | | | Joined: May 2005 Posts: 74 'Bolter | | 'Bolter Joined: May 2005 Posts: 74 | Ed, are you talking about an international motor and trans? I would certainly consider it if I had access to that combo. | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | If you do decide to use the 283, I'd suggest a few more gears- - - -like maybe a 2 speed rear end, or a Brownie. As I mentioned before, a lugged-down short stroke engine won't get out of its own way. I'd suggest a big block Chevy for doing some serious freight hauling- - - -a 427 or 454. You can find some low mileage big blocks in retired motorhomes. Jerry
