4 members (dt235sd, KEVINSKI, Otto Skorzeny, Charles in CA), 90 guests, and 0 robots.
Topics128,051
Posts1,055,732
#1396347 02/08/2021 10:24 AM
I've looked under door parts, door rubber, and a couple of other places but I can't find the 1.5" and 2.5" pieces of rubber that slip under two horizontal bars inside the doors of my '46 Chevy truck. Anyone know what they're called, or where I can buy replacements for them?
1946 Chevy
Getting started on Bruno
You can't buy happiness but you can buy a truck ... and that's pretty much the same thing.
To my knowledge no one makes this rubber strip. I went to Lowes and compared mine to material in the roofing and hardware dept. Do not remember what I used but get something similar. The stripes are anti squeak/vibration strips and no one will ever see them once the door panels are installed. If yours are not destroyed, try cleaning them up. Check this YouTube.
Harold
Harold
Thank you, Harold! I definitely know that I"ll need to put something there. Mine are curved/crazed so I'll just have to take them with me for size reference. I appreciate the headache that you saved me! =)
1946 Chevy
Steele Rubber Products has a section of their facility that will match size/profile of any piece of rubber. Also their catalog has a section with photos of profiles so you logically could find something from another vehicle that would do the job. Catalog is free for the asking. Complicated website though.
The door weather strips for my 49 pickup were missing and my door gaps were to tight to use the orignial rubber so I found what I needed on fleabay. Be it peel and stick or glue on there is a ton of rubber products available. As Harold46 mentioned, nobody will see them go find what you like and what works for your doors. Download Steele Rubber Products catalog as it has much more to look through than what's shown on their website. The second link is a kit that may have what your looking for.
https://www.steelerubber.com/assets/site/docs/universal_catalog_sept_2020_web.pdf
http://www.vendio.com/stores/bobscl...9-1946-chevrolet-gmc-truck-/lid=43006155
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
Thank you, everyone! We were on the way to Lowes when I saw this so I'd they don't have anything then I'll definitely check out that catalog/site. Much appreciated!!
1946 Chevy
