3 members (Otto Skorzeny, TexasA&M48Truck, 1 invisible), 63 guests, and 3 robots.
Topics128,026
Posts1,055,404
Members48,422
#1396290 02/08/2021 12:30 AM
1 Offline
hello , i have a 1939 chevy truck , up dated to 12 volt system , i would like to put in a brite headlight indicator in the dash that signals when the the head lights are on brite .
what type of dash lite do i need ? and how is this wired in properly ? thank you 1Pete1
Ex Hall Monitor
Ex Hall Monitor
I know up to 1938 the high beam indicator was an accessory that clamped to the bottom lip of the dash. I'm not sure when they put the high beam indicator in the speedometer housing. If you don't have a socket in your 39 it likely was under the dash as well. If you can even find one hold on to your wallet. If you're not concerned about being "correct" you can do whatever you wish. Hang a small light under the dash or drill a hole in the dash & put al light there. Tie it into your high beam circuit. Whatever trips your trigger.
I installed a small colored light in the dash on my 39.
Another quality post.
Real Trucks Rattle
When I installed a bigger headlight assembly on my Harley, I used a small bright blue LED in the chrome housing as a high beam indicator. They're available on Ebay in all sorts of variations and they're dirt cheap. They also work on 6 Volts at full brightness, if you're still running the original electrical system.
