3 members (delky, Hotrod Lincoln, Rich'sToys), 78 guests, and 0 robots.
Topics128,049
Posts1,055,740
#1395536 02/02/2021 11:16 PM
I have a 60 model 261 engine with 3.55 rear. According to my calculations I am running about 3100 rpm at 70 mph. This a daily driver and some time on the highway. I guess I am concerned about what kind of highway rpm's the engine will tolerate without damage. The engine is stock.
Thanks, Pete
Moderator, Electrical Bay
Hi Pete and welcome to the place. That's a bit higher than I like by 500 to 800 rpm, but should be ok as long as the engine is in good nick.
~ Jon
I would run it at 65 max personally. Then again, I started out with babbit bearings and iron pistons and max @45mph. Your 261 is probably much more stout. But I am on the safe side with these. Nice combination BTW.
'38 1.5ton; "The stuff is as tough as woodpecker lips"
The 261 was the big truck 6-cylinder and was governed at 3600 rpm which is where max HP is made. Back when they were being worked every day they would run them wide open all day long so don't be afraid to step on it!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
3,100 RPM is only 2,034 feet per minute piston speed, well below the informal 2,500 f/m suggested for sustained cruising.
Don't worry about it.
H Online: Content
"Drive it like you stole it"- - - - -these old engines are a lot tougher than the snowflakes with lace on their drawers think they are. The cylinder head design won't allow much over-revving unless maybe you're running wide open in granny gear on a SM-420. Any cruising speed under 4K RPM in high gear isn't likely to do much damage to an engine with a good lower end, particularly one with good oil pressure and rod bearing clearance under .002"
Pete V #1395805 02/04/2021 10:52 PM
Thanks for all the input. Much knowledge here.
panic #1395885 02/05/2021 2:08 PM
Panic, Where did you get this information? Looks like some good data.
Thanks, Pete
F/M = stroke X RPM / 6
