3 members (dt235sd, cmayna, Hotrod Lincoln), 102 guests, and 2 robots.
Topics128,142
Posts1,056,490
Members48,442
Gentlemen, I recently found a 1987 S10 long bed (118" from hub to hub) right around the corner for almost nothing and got it to go under my 1951. That being said, I'm wanting to do a 4" front and 4" rear drop on it.
Does anyone have recommendations on the best S10 lowering kits available? I'm also not looking to break the bank.
colby
1952 Chevrolet 3100: Photos
Engine: 219 L6 to 250 L6 to 350 V8
Transmission: Borg Warner T56: 6 Speed (1994 Firebird)
1955 Chevrolet Bel Air
Engine: 265 V8
Transmission: Three Speed
Currently: Rebuilding Engine & Differential
1956 Chevrolet 6400
Engine: 250 L6
1958 Chevrolet Apache 3600
Currently: In Barn
1963 Chevrolet C10 Fleetside
Currently: In Barn
Crusty Old Sarge
Crusty Old Sarge
Belltech 2" drop spindles and 2" lowered coils in the front, 4" inch blocks in the rear. A word of caution... I would mount your sheet metal to the chassis and then figure out your ride height. An "AD" on an S10 chassis sets lower than stock already, I mounted a 50 on a Code 504 S10 frame kit and it sat pretty low. My point is you can always adjust the afterwards.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Agree with Tuts. The ride height will also be affected by engine and cab weight....
Spend the money to figure the ride height at the end. If you can finish a body swap, dialing in the stance is easy money.
TUTS 59, thank you! And yeah, I'm planning on doing that for sure. I've questioned the Code 504 guys a ton and also have asked them about their photos online and they have given me a ton of info on it so far. They don't recommend going lower than 4" x 4" because of drag issues.
Hink, I'm running a GM 350 and adding 240lbs with my big rump in the driver's seat.
I plan on running an 18 or 20" rim x 8" wide with an overall diameter between 27-29" on the rear (they said don't exceed 29" with their kit and a 4" x 4" drop). If I go wider on the rim and wider than a 10" tire, I will have to cut out the fender. I'm not sure that I want to do that yet, but I have a bit before I get there, so we will see. On the front, I might go with 18" or 20" rims x 8" wide but with an overall diameter of around 26-27" and that's with a 1 1/2" spacer, that's required.
colby
Engine: 265 V8
1956 Chevrolet 6400
Engine: 250 L6
Currently: In Barn
Currently: In Barn
The 350 is going to drop that front end a bit more than the 4 or 6 cylinder the S10 originally came with.
Sounds like you have a good plan. Keep up on photos and records of what you put in as you get it. It'll help later on with maintenance.
Don't worry about a V8's weight as the front suspension was designed to work with the truck fully loaded which put way more weight on the front than a V8 on an empty truck. I second trying the completed truck before doing an lowering. We have done several that the customers wanted RAISED after the S10 conversion. Pic of a 52 with all stock S10 suspension. Note the 2.5" exhaust is touching the grass and the bottom of the running board.
[img]https://i.postimg.cc/4HNJCdr0/IMG-4905.jpg[/img]
Evan
Here's another way to do it.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Hink, thank you! Have you seen any of the photos of what I'm doing? I try to keep the album linked in my signature updated.
Coilover, I appreciate the photo. That makes me realize that I should try it out before just lowering it. The Code 504 folks said that their conversion kit (I'm getting that as soon as I get my transmission confirmed) will lower it about 2.5" from stock. Then I could go from there after seeing how it all sits on the wheels I plan to get.
Whitedog, I think you have something going there! Gonna make some scrap money, I see! 🤣
colby
Engine: 265 V8
1956 Chevrolet 6400
Engine: 250 L6
Currently: In Barn
Currently: In Barn
Crusty Old Sarge
Crusty Old Sarge
Colby, why don't you start a Project Journal, you can document your progress there and up load pics for us to look at. grin
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
I second Craig’s suggestions. You can upload your photos to a thread in the Project Journal Forum. Buy doing that everyone can see your project without having to leave the site. This thread is behind you now.
BTW, you can always come back to HiPo and start a new thread with another specific component question.
