3 members (Otto Skorzeny, DennisM, 1 invisible),
140
Mod | | | Forums66 Topics128,281 Posts1,058,461 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2020 Posts: 284 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 284 | Is there any assembly drawings for the 4 speed transmission? I tried to search, but every time I've tried that, I get 1000 search results and most if not all have nothing to do with my search question. I would specifically like to see how the shifting lever anti rotation pins are put together. The shift lever on my trany has some side to side movement that I would like to correct. I have repaired my Allis Chalmers WC trany lever and this is a little different.
1947 3600 Chevy
| | | | | Joined: Sep 2010 Posts: 2,354 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,354 | If it is a Muncie sm 420 there should be some pictures on the web. | | | | | Joined: Sep 2010 Posts: 2,354 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,354 | If you google Muncie sm420 diagram there is a shop Manuel you can download | | | | | Joined: Sep 2009 Posts: 123 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 123 | | | | | | Joined: Dec 2020 Posts: 284 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 284 | Thanks, If I have to go deeper into it, this will be of great help.
1947 3600 Chevy
