1 members (klhansen), 113 guests, and 2 robots.
Topics128,072
Posts1,055,904
Members48,429
#13949 04/20/2004 8:09 PM
Gentlemen,
When installing my latest 1954 235 engine in my '53 truck, I opted for a modern-style remote oil filter unit that uses a spin-on type filter. My oil pressure pegs out the 30 lb. gauge at idle, but decreases to the 15-20 lb. range at higher rpm. I know the engine is the "high pressure" 235 and this seems like too low an oil pressure. I know that the "full flow" oil filter decreases oil pressure. What are some acceptable guidelines? Thanks for the advice.
Regards,
Tyler Watts
1953 3600 Pickup
1946 Fleetline Aerosedan
1948 Hudson Commodore
#13950 04/20/2004 8:54 PM
Did you put a restrictor on the oil filter to keep the flow down? You need one. Since the filter is a bypass filter it will starve the engine for oil if the filter flows too much.
30psi is an acceptable oil pressure for a 235. The pressure should never drop at higher RPM.
Paint & Body Shop moderator
#13951 04/21/2004 1:58 AM
Mr. Bartlett,
Thanks for the advice. Where can I obtain said restrictor and what will it cost me? I have also heard that a larger filter will mitigate the drop in oil pressure. Would that alone be a sufficient solution?
Regards,
Tyler Watts
1953 3600 Pickup
