5 members (VEW, 50Chevy3100, J Lucas, Wally / Montana, Wickedbass), 89 guests, and 0 robots.
Topics128,075
Posts1,055,918
Members48,429
#1394384 01/26/2021 12:24 PM
Has anyone seen or heard about adding shoulder strap seat belts to 60-66 suburban or panel? There appears to be a little bit of room behind driver door prior to first window and I wonder if there is enough there? I am reluctant on the passenger side because of the folding seat, but if I could protect at least the driver I would be happier.
~ HB
1962 Chevrolet C10
1962 Suburban
Hey Hambone
If you go to Juliano’s seat belt site, and look at the install pics
you’ll get a good sense of how to install the upper shoulder belt
Retainer that needs to be bolted or welded ( in my case).
That retainer brace is quite narrow and should be very doable in your
Burb.
In my case I elected to surface weld it since I was upholstering over that area
anyway. But, as you’ll see in the pics, you can fish it up into place behind the interior
Sheet metal if the situation allows....
Hope this helps.
Thanks I will check on it.
~ HB
1962 Chevrolet C10
1962 Suburban
mine only has seat belts
Wylie johnson
