| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Has anyone seen or heard about adding shoulder strap seat belts to 60-66 suburban or panel? There appears to be a little bit of room behind driver door prior to first window and I wonder if there is enough there? I am reluctant on the passenger side because of the folding seat, but if I could protect at least the driver I would be happier. | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | Hey Hambone
If you go to Juliano’s seat belt site, and look at the install pics you’ll get a good sense of how to install the upper shoulder belt Retainer that needs to be bolted or welded ( in my case).
That retainer brace is quite narrow and should be very doable in your Burb.
In my case I elected to surface weld it since I was upholstering over that area anyway. But, as you’ll see in the pics, you can fish it up into place behind the interior Sheet metal if the situation allows.... Hope this helps. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Thanks I will check on it. | | | | | Joined: Feb 2015 Posts: 23 'Bolter | | 'Bolter Joined: Feb 2015 Posts: 23 |
Wylie johnson
