1 members (Brian Moore), 55 guests, and 3 robots.
Topics128,030
Posts1,055,423
Members48,422
#13943 02/08/2005 11:02 PM
My truck has never had the heat riser spring and I can't figure out where exactly it installs. There's freedom of movement on the riser, as turning it with my hand is a snap (I understand these things stick quite regularly).
If anybody has a picture they could post regarding the spring, I'd greatly appreciate it. I'm assuming it doesn't install internally, meaning within the exhaust manifold. Thanks in advance for your help!!
There was a little steel rod sticking out of the manifold parallel to the riser shaft. It has most likely rusted away. The outside of the spring hooked on it and the inside of the spring fit in that slot on the shaft.
This belongs in Engine&Drivetrain so look for it there.
Paint & Body Shop moderator
Make sure you hook the spring on the post in the right direction. The previous owner of my 261 has it on backwards which had to produce "au contraire" results.
It wraps over the post pointing toward the engine. And you slip it on the slot so about a half a turn gets it over the post. My '48 Shop Manual gives those instructions and I used them for my '61 261.
