5 members (dt235sd, Toadwart, Chip O, 2 invisible), 106 guests, and 1 robot.
Topics128,087
Posts1,055,998
Members48,430
so im almost finished the rebuild on my sm 420, and i noticed these electrical contacts on my gearshift when i was installing it to test it, being as my other electric switch is somewhat temperamental id like to find the missing piece(s) to use the one in the knob. has anyone found a source for this? my usual guy hasn't ever seen one like it apparently.
I've never seen that type of knob/switch combo.
What brand rear do you have? Looks like it's a 2-wire connection...the switch will need to match the electric motor on the rear.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
TGP Offline
That was common switch on mid/late fifties mostly GMC and some Chevrolets with electric two
Speed.
Hard to find, even the push pull are getting hard to locate.
They sometimes pop up on ebay.
Good luck
Tom
Tom,
I've seen the Chevrolet vacuum push/pull and the Eaton red knob push/pull switches (https://www.amazon.com/Four-Seasons-35802-Speed-Switch/dp/B000DCNFAM), but never seen the knob the OP has on any Chevrolet TF trucks...must have been a GMC thing...could it be Timkin related?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
TGP Offline
I think Timken electric two speed rears is correct.
I meant to add that to my reply that the trucks I've seen with that switch
Did have Timken rears.
The 58 task force GMC in my signature has that switch only in 5 speed.
Has Timken rears,
Maybe someone has late fifties GMC parts book that can confirm "Switch knob assembly"
with what rear end option and even a GM part# which greatly helps in searches.
Have a spare in my cabinet.
Tom
I had a 2 speed shifter on my 1957 550 series. It was a 1998659 which was superseded by a 1998658. They were both obsolete while I had the truck. I replaced them with an Eaton 032861 push pull switch. Google the Eaton part number and you will find them for sale all over the place. I had a 3 speed Eaton on a 1964 model that used a switch on the gear shift. I found one of them on eBay.
https://photos.app.goo.gl/mahmUXZXExmdnkRq8
I bought a 2 speed shift knob on eBay for one of my 550s quite a while, but they are rare.
That looks like a good option that Eaton one, I'll have to look into that
