1 members (Bill Hanlon), 138 guests, and 3 robots.
Topics128,115
Posts1,056,288
Members48,439
#1392733 01/15/2021 11:53 AM
Moderated
Moderated
Hi All!!
I'm new here, and working on my first 235. During the process of tearing the engine apart I hear something hit the shop floor. I look down and find the little metal thing pictured in the attached images.
What is it? Where does it go?
Thanks so much in advance for the help!
- Dan
[img]https://lh3.googleusercontent.com/d...vqg3uszWqBRFLo=w1518-h2022-no?authuser=0[/img]
https://lh3.googleusercontent.com/f...igQM60tgyx9SMw=w1518-h2022-no?authuser=0
Just a guess but could it have come off the foot of the fuel pump
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Ex Hall Monitor
Ex Hall Monitor
What part of the engine were you working on when it fell? That might give you a clue.
It appears to be some type of tab for locking something in place. On the backside edge there are remnants of where it pivoted and the male protruding pin would have locked into something indented, somewhere lol.
I'm picturing stamped sheetmetal parts - like a tall oil cap 1/4 turn locking into position, part of a baffle or brace in stamped rocker covers, heat stove pipes, air cleaner base, fan shroud.
It's likey NOT a mechanical part. You will know what it is when you need it and get further along with your cleaning...
Some fuel pumps have that on the fuel pump arm. It has that wear mark on it. I have 1 in my shop right now.
just retired and finally making headway on my project truck. 1940 GMC AC152.
Moderator
Moderator
2 Offline
That does look like a piece that would be in the crankcase and a wear well lubed wear mark on it.
Good eye GIM! (Short for “gmc-is-me”)
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Looks like the bottom of a magazine for a semi-automatic hand gun.
X2
BC
1960 C60 pasture art
Backing Plate for the Door Catch?
1951 Chevy 3100 5-window
261 cu in, 348 Head, Split Fenton Exhaust
Offy with Dual Weber 2 Bbl Carbs
I have torn down a number of 235s and 216s down to bare bones for rebuilding and have never seen anything close to that part.
Maybe someone was cleaning that part up on a bench mounted wire wheel and slung that part into never-never land.
Dan,
As Kevinski and gmc' said, its the rubbing block off a newer replacement fuel pump actuator arm (first image, AC 4666, non-glass bowl). The original pumps had a different style, laminated pump arm, that doesn't include that piece (second image, AC 9797, glass bowl). Both pumps shown in the images are NOS units.
Apparently, the pad from a pump used on your engine separated from the fuel pump actuator and dropped into the crankcase at some point in time.
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
