Topics128,132
Posts1,056,386
Members48,441
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Hello, I have a 1946 2 ton chevy project and I could use some help identifying what kind of rear end I have. Any help is appreciated Thank you
1939 Chevy 1 1/2 ton with 216
Crusing in the Passing Lane
Don’t know mfg., most likely corporate, ratios 5.64-8.?? Stamped on there. Are you needing parts or ? Ed
Hy Libby007, welcome, the differential in your pictures is a Timken double reduction two speed, quite common in those years and up into the early fifties.
Thanks for the help, don't need any parts yet as far as I know, just wanted to know what I had. Inherited the truck from my grandfather who had it as a parts truck for his 46 1.5 ton, need to finish the brakes and i'll be putting a '58 235 in for an engine. It's going to be a dump truck when finished
