1 members (baldeagle),
106
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 249 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 249 | So the 1951 216ci engine is mostly apart after a over heating problem and suspected bad head gasket. Turns out that the water jacket was fairly well plugged with radiator stop leak crap but I am concerned about the flatness of the head. How many thousands of an inch can the gasket tolerate? A precision straight edge shows a .002/.003" variation. I would think that would be okay but don't really know.
1950 3600 1951 4400 Gazz
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | 216 heads are notorious for developing cracks. I'd have a good machine shop do a .010" cleanup cut on the gasket surface, and do a magnaflux crack inspection at the same time. Heads can tolerate a lot of milling with no ill effects, at least until the intake valve to piston clearance gets too close. Up to 30 thousandths or so shouldn't be a problem, but don't take off more than is needed to get the gasket surface flat. Up to .005" is probably acceptable without doing any milling on a head gasket change, but as always, "the flatter the better". Don't forget to check the block with that straight edge- - - - -it's pretty rare, but not impossible to have a warped top surface on the block. Jerry
| | | | | Joined: Mar 2006 Posts: 249 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 249 | Thanks for that response. I'm probably going to pass on the magnaflux though but will check the block. Hope I don't regret it.
| | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | Magnafluxing is not that expensive for peace of mind!
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Absolutely magna flux. If the head is bad from cracks you will still have the problem.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Mar 2007 Posts: 3,374 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,374 | Depending on how far down you have pulled the block, I would look into getting it boiled out. If it had enough stop leak in the head to cause overheating issues you might want to start with a clean block as well. .. If you are going to reassemble the head and run the engine I would use a block flush at that time and insure a clean block just the same.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Mar 2006 Posts: 249 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 249 | Thanks for the replies and suggestions. I am having this work done by a mechanic friend and when I went to see him the other day about it he had the engine mostly back together - the head was on in any case so no magnaflux or milling. He is going to remove a couple of the soft plugs to flush the water jacket out as the crank and pistons were still in the block. He did have a question about the front engine plate and gear alignment. The gasket kit came with two different gaskets for this and we are both guessing it is to establish correct gear engagement between the primary and cam gear. The manual I have does not address it and he could not find any info on it either. Anybody have any comments on that?
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Unless you have removed the camshaft, there's no way to change the gasket between the plate and the block. The timing cover gasket might have some subtle differences from different years, but if you're referring to the plate-to-block gasket, compare them and use the one that matches what came off. Either way, there's no way I know of to adjust the fit of the timing gears. Jerry
| | | | | Joined: Mar 2006 Posts: 249 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 249 | He did take the cam out. I'll forward this info to him. Thanks!
