0 members (),
72
7
Mod | | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2021 Posts: 2 Moderated | | Moderated Joined: Jan 2021 Posts: 2 | Good evening
Hope you guys can help
Rebuilding a 1951 216 car engine
Here is some background Engine was running when I started the rebuild but started smoking and leaking oil heavily on the block
This is the original engine and this was the first rebuild
I had the crank machined and it was in tolerance for original size bearing
After reasambly with all new bearing,rods,rings and tolerance set to spec
Once crank and rods are in and fully tightened the engine will not turn by hand,. Loosening the mains the engine will turn freely
Any ideas as to why it will not turn when fully tightened and what would be the next steps
Thank you | | | | | Joined: Jan 2021 Posts: 22 'Bolter | | 'Bolter Joined: Jan 2021 Posts: 22 | Have you plasti gauged it to see if one of the journals is biting harder than the others? | | | | | Joined: Aug 2007 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 23 | How did you prepare the rods? If they were re-babbited did you use new shim sets and set the clearance as per the shop manual? If the rods were machined for modern inserts did you doublecheck with plastigauge?
It's not uncommon for a fresh 216 to be very tight until you start to get everything wear mated. Judging resistance at the crank is deceiving too when everything is fresh. Can the starter spin it at all? | | | | | Joined: Jan 2021 Posts: 2 Moderated | | Moderated Joined: Jan 2021 Posts: 2 | using rebabbited rods and yes new shims were used to se the clearance
i will try using the starter and see if it turns over
please let me know if you have any other ideas | | | | | Joined: Feb 2020 Posts: 47 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 47 | a newly installed rear main rope seal will cause the crank to turn VERY hard.
just retired and finally making headway on my project truck. 1940 GMC AC152.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | So your problem is with the mains or the seal, not the rods. I don't know how you shimmed the mains but usually they are done one at a time, with it loosened after fitting while work continues on the next one. Sometimes when they are all done up after, the crank won't turn. To me this indicated an inaccurately aligned bore. I experienced this on my truck 216. I found out which main caused the problem, added some shimming and all was well. That was forty thousand miles ago. | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | It's also important to shim-adjust the main bearings for the proper clearance BEFORE installing the rear seal. Instead of Plastigauge, I use a thin slice of .002" shim stock between the lower bearing shell and the crankshaft, and shim until I can turn the flywheel with a firm pull. Then move the shim on to the next main and repeat the process. Once the crank will turn with all the mains torqued, THEN deal with the rope seal. Jerry
