9 members (3B, Johnny Rib, baldeagle, 68ironhead, 2-Ton, 1955 1 Series, JW51, Guitplayer, walter74),
108
Mod | | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2017 Posts: 147 'Bolter | | 'Bolter Joined: Sep 2017 Posts: 147 | Just curious on thoughts about replacing the rear cab panel from the belt line down? I have seen were people have replaced the entire thing panel and other were they left an inch of original sheet metal along the top and sides and patched the new one in place. The results looked really good in both cases. My rear cab panel has a fair number of small dents but is oil canned quite a bit in a few spots and I am not comfortable with the shrinking process or chasing oil canning from one spot to another. Also, to be honest Im not sure I really need to care about the oil canning since it is predominantly behind the bed but just wanted to see what people typically do.
Thanks!
1950 Chevrolet 1/2-Ton 3100
| | | | | Joined: May 2015 Posts: 11,009 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,009 | I have a bit of that on the lower rear of my cab, but replacing the whole thing would be more than I'd want to tackle. As far as shrinking, that's not that hard, and MP&C's posts here and on the forum that he has a link in his signature to have some good tips on that. Any dent is going to stretch the metal a bit, and you have to deal with that. Hammering each dent flat contributes to the oil canning. I have some dents in the vicinity of the three stretchers inside the cab that will be hard to get out, and I'll probably use a bit of filler to deal with those. As far as behind the bed panel, I may not get too carried away with getting that perfect either.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | There is no typical. It all depends on the severity of the issue. It seems your issues are "a fair amount of dents" and "oil canning". This does NOT fall into the category of panel replacement unless you have bad rust also. It also depends on your own feeling and anxiety about an issue. It depends on the level of "restore" you envision. It depends on if you are dwelling on something that is not a big deal to live with. "Dents" are intentionally put into large flat panels to stiffen them. They are called dimples and beading. Linear or cylindrical. these are put in before the metal is "retained" by welding or other means. Your dents/dimples were put in after. Small dents stretch small. Big dents stretch big. They may or may not have a small counter effect somewhat in strengthening the panel but not near as much as a well designed dimple before retention.
As has been said, you would have to dolly the dents carefully or heat/disc shrink them and avoid further oil canning. All without experience and at a place that offers no way to get a dolly on one side and a hammer on the other if that method is used. When someone says "it's not too hard to do" it's always hard to do for me for the first time. A large rear cab panel is way too risky for you to do any hammering or shrinking or replacement, according to the reported location, severity and type of issue.
The small dents can be filled, as said, and the oil canning stiffened by using some sort of large pieces of sheet material bonded on the inside, if it all bugs you that much. If you fill, apply thin fill to entire panel and sand down to flat. Don't fill each hole.
If it's not making noise and it is 75% covered by the bed bulkhead and not rusted......leave it alone....but you are an engineer so you can decide what makes the most sense.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2015 Posts: 11,009 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,009 | I have to agree with what Bartamos said. Good advice. You have to assess your own situation and capabilities.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Welding an entire rear panel will have its own risk of warping and oil canning it is a huge panel with little to any structural support of its own.
| | | | | Joined: May 2015 Posts: 11,009 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,009 | Welding an entire rear panel will have its own risk of warping and oil canning it is a huge panel with little to any structural support of its own. Very true.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | You will have to join All Metal Shaping to view the pictures in the link below, but this thread is of a 41 Chevy pu where the area above the rear window is replaced to get rid of inside deep pitting, also includes roof repairs and rear cab panel fabrication and replacement. May give some insight to the job. Regarding the warping from welding, that issue gets fixed by planishing, and is covered in the MIG welding tips and tricks sticky at the top of the page here in the paint and body shop forum. Looking at this link below, you can easily see the results of proper planishing of the weld. https://www.allmetalshaping.com/showthread.php?t=19718 | | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | What are you talking about??? That awesome really. Cant see any of em. Great job. In fact looks like id be afraid to touch it, as opposed to drive it. Ha. | | | | | Joined: May 2015 Posts: 11,009 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,009 | Robert, you're right, that was a LOT of welds. Was that done with TIG? If I had a project that needed that much welding, it would be a valid excuse to buy a TIG machine and learn to weld with it.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Here’s another project truck that shows quite a bit of work in the roof to fix someone’s botched chop job that was left to collect dust. Some impressive work, and inspiration https://www.garagejournal.com/forum/showthread.php?t=461712 | | | | | Joined: Sep 2017 Posts: 147 'Bolter | | 'Bolter Joined: Sep 2017 Posts: 147 | There is no typical. It all depends on the severity of the issue. It seems your issues are "a fair amount of dents" and "oil canning". This does NOT fall into the category of panel replacement unless you have bad rust also. It also depends on your own feeling and anxiety about an issue. It depends on the level of "restore" you envision. It depends on if you are dwelling on something that is not a big deal to live with. "Dents" are intentionally put into large flat panels to stiffen them. They are called dimples and beading. Linear or cylindrical. these are put in before the metal is "retained" by welding or other means. Your dents/dimples were put in after. Small dents stretch small. Big dents stretch big. They may or may not have a small counter effect somewhat in strengthening the panel but not near as much as a well designed dimple before retention.
If it's not making noise and it is 75% covered by the bed bulkhead and not rusted......leave it alone....but you are an engineer so you can decide what makes the most sense. Bartamos, the part really doesnt have any rust and since I am so new to metal work and welding I think I will hold off on it. I have visions of the panel not fitting well and the cab shifting once the back panel is off and that is enough to keep me from attempting it. Typically any panel work I have done so far I do the passenger side first then the drivers side. The first side is always rough because I haven't done it before and the second side is typically better and a little quicker. I did buy a dent puller from HF that for getting out the cab dents that don't have access to both sides so that should be a fun new adventure, lol. Thanks of the advice on applying a thin coat to the entire panel and not each small dent or depression. I definitely would have just filled individual holes. Thanks, Eric
| | | | | Joined: Sep 2017 Posts: 147 'Bolter | | 'Bolter Joined: Sep 2017 Posts: 147 | Robert, That is amazing work I would love to take a class in something like that some day but unfortunately work gets in the way for now. Do you know if anyone offers classes on metal forming or I have seen it referred to as coach building? I follow a Facebook page called coach building and they create entire automobile exteriors, just unbelievable workmanship. Thanks, Eric
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Dongray Have had some shrinking lessons from the lead bodyman of old. I once had an oilcan panel he went and got a FLAT round body hammer ,it was not well-used but he did say it had to be flat. He heated up a spot about like a silver dollar-it just puckered right up and he dollied it from behind and hammered it FLAT 2 more times of that and that panel was streched tight. Scuffed it primed it blocked and painted looked fine ! | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | MPandC That oblong matal meet is in the only oblong in my county ! It is well attended !! | | |
