| | | Forums66 Topics128,141 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2017 Posts: 3 Moderated | | Moderated Joined: Nov 2017 Posts: 3 | Hello. I’m sure it’s been asked plenty of times. How ever, here it goes. Has anyone ever painted their engine block I with car paint? You know, maybe to match the vehicle. Was it successful? Any tips would be appreciated Thanks | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | I don't think it's the color so much as the ability of the paint to tolerate heat, oil and gasoline.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | may wanna check with Bill Hirsch Paint, they make engine paint and such, great folks with a quality product . They may know of someone who handles paint like that. | | | | | Joined: Apr 2017 Posts: 230 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 230 | Most of the enamel paint sold by the suppliers is made by PPG. It’s called ALK-200. It’s a industrial grade enamel. You can get it in any color. Brush or spray. Good product. You can get it at most, not all, PPG auto paint supplier. I also use it as the body paint because I don’t like the wet look of the base/clear coat used on modern cars.
Mike
1940 Chevy 1/2 Ton presently... Almost done 1940 Chevy Business Coupe... In pieces
