0 members (),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Can't bust em loose? They strip out? Frustrated? Buy This. Buzz it and buzz it with your air chisel motor and then turn while buzzing some more. Greatest tool for $18 you can buy. Heat, liquid wrench and this on the really ones. The vibration is the key, Works the oil down in, busts the rust and shakes her loose.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2004 Posts: 2,413 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,413 | Interesting, never seen or heard of such a tool. I thought for sure the link would show a hand impact tool. The type that requires the use of a hammer.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Same principle just uses air.
| | | | | Joined: Sep 2010 Posts: 1,709 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,709 | I made a couple of these when I rebuilt my truck. One is a straight blade and one is a phillips head welded to a pointed tip and a screwdriver handle welded on the side. It will back out a screw very easily. There should be one in all tool boxes. I like the interchangeable tip on this model. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Actually it is not the same principle as the hammer type. This one has several differences/advantages. You provide the turning with your hand on this one. The hammer blows provide the turn on the other. That can damage what you are trying to disassemble. For example: if you are trying to get a hinge off of a door jamb, the hammer type will bend the jamb inward and deform the area before you get the screws loose. There are other places where this can happen also. A motor can be irreparably damaged and etc. The are times you have no room to swing a hammer.
Wayne, you can "chuck up" an old valve to flatten metal.
A heavy equipment field mechanic will take off bolts on some big part and it won't free up. They use a flattened chisel or bar on their air motor and vibrate the object all over it. Then it comes loose. No room to swing a hammer to tap it all around.
Another tool I have similar to all this, that takes off hardened grease, is a Harbor Freight needler. Super good.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | I made one of those and formed the business end to 3/8" do that i can use sockets and adapters to use hex shaft clutch head and other bits. That tool very seldom fails me.
| | | | | Joined: Feb 2004 Posts: 29,818 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,818 | My Black & Decker 3/8" drive battery powered impact wrench has a variable-speed trigger that allows me to do the same kind of thing. Hold firm pressure against the screw head after soaking the stubborn screw with KROIL for a while, and gently hammer on it in both directions. It's a lot simpler than hooking up an air line, firing up the compressor, etc. Jerry
| | | | | Joined: May 2015 Posts: 11,078 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,078 | I've had similar success with a 1/4" drive Dewalt impact driver. Gently working at it is the key to getting stubborn fasteners loose without destroying the head. That and a proper fitting bit.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2010 Posts: 1,709 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,709 | Wayne, you can "chuck up" an old valve to flatten metal. How does it stay in the air hammer without the raised area behind the spring? Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | You said you made something like this so I thought you could make one with an old valve. I don't know how you made the others.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2010 Posts: 1,709 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,709 | You said you made something like this so I thought you could make one with an old valve. I don't know how you made the others. I would have to weld the valve to one of the factory tips  Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | |
