3 members (Hawkman, Otto Skorzeny, Peggy M), 202 guests, and 3 robots.
Topics128,078
Posts1,056,057
Members48,433
#13908 05/31/2005 5:07 AM
I Have just pulled My 216 to replace with a Pre-53 235. The No. 1 cylinder piston bearing needs to be replaced. Obviously I will replace them all since I have it out. Is it as easy as just putting new bearings in. Or do I have to send it out to get babbited? Im trying to go cheap as possible. Thanks alot in advance, Jess
1951 3100
#13909 06/01/2005 12:14 AM
A pre 53 235 would have babbitted rods, from the factory. You either would have to get a reconditioned rod, get your rod reconditioned (somewhere?) or have it machined to take the inserts. The third way is what I would recommend.
1951 1 Ton Completed
#13910 06/01/2005 5:10 AM
Does #1 need a new rod, or can you adjust it enough by removing the shims between the rod and cap? Was it knocking?
To be long remembered as he's cruising in
The Passing Lane
#13911 06/01/2005 7:09 AM
Im not sure if it was knocking cause I never heard it run. About the shim adjusting Im not sure how to do that. thanks alot for the replies, Jess
1951 3100
#13912 06/01/2005 4:23 PM
Is the crankshaft round and smooth on that cylinder? If so, you can just replace the rod from the bottom. Pull the piston down in the cylinder far enough to expose the wrist pin, loosen or remove the clamp bolt, and slide the wrist pin out by shaking the rod from side to side. Measure the crankshaft with a micrometer to see if it's been ground undersize, and buy a reconditioned rod with the babbit sized correctly for the crankshaft diameter. If more than one rod bearing has problems, I'd reccomend a full overhaul, and probably a conversion to insert-type bearings by getting the rods machined to accept a removable bearing.
