1 members (Millenimech), 118 guests, and 2 robots.
Topics128,135
Posts1,056,422
Members48,441
#1390336 12/30/2020 12:06 AM
Sir Searchalot
Sir Searchalot
Can't bust em loose? They strip out? Frustrated? Buy This. Buzz it and buzz it with your air chisel motor and then turn while buzzing some more. Greatest tool for $18 you can buy. Heat, liquid wrench and this on the really ones. The vibration is the key, Works the oil down in, busts the rust and shakes her loose.
Former Workshop Owner
Interesting, never seen or heard of such a tool. I thought for sure the link would show a hand impact tool. The type that requires the use of a hammer.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Same principle just uses air.
back yard wrench turner
I made a couple of these when I rebuilt my truck. One is a straight blade and one is a phillips head welded to a pointed tip and a screwdriver handle welded on the side. It will back out a screw very easily. There should be one in all tool boxes.
I like the interchangeable tip on this model.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Sir Searchalot
Sir Searchalot
Actually it is not the same principle as the hammer type. This one has several differences/advantages. You provide the turning with your hand on this one. The hammer blows provide the turn on the other. That can damage what you are trying to disassemble. For example: if you are trying to get a hinge off of a door jamb, the hammer type will bend the jamb inward and deform the area before you get the screws loose. There are other places where this can happen also. A motor can be irreparably damaged and etc.
The are times you have no room to swing a hammer.
Wayne, you can "chuck up" an old valve to flatten metal.
A heavy equipment field mechanic will take off bolts on some big part and it won't free up. They use a flattened chisel or bar on their air motor and vibrate the object all over it. Then it comes loose. No room to swing a hammer to tap it all around.
Another tool I have similar to all this, that takes off hardened grease, is a Harbor Freight needler. Super good.
I made one of those and formed the business end to 3/8" do that i can use sockets and adapters to use hex shaft clutch head and other bits.
That tool very seldom fails me.
H Online: Content
My Black & Decker 3/8" drive battery powered impact wrench has a variable-speed trigger that allows me to do the same kind of thing. Hold firm pressure against the screw head after soaking the stubborn screw with KROIL for a while, and gently hammer on it in both directions. It's a lot simpler than hooking up an air line, firing up the compressor, etc.
I've had similar success with a 1/4" drive Dewalt impact driver. Gently working at it is the key to getting stubborn fasteners loose without destroying the head. That and a proper fitting bit.
How does it stay in the air hammer without the raised area behind the spring?
Wayne
1989 Silverado
Sir Searchalot
Sir Searchalot
You said you made something like this so I thought you could make one with an old valve. I don't know how you made the others.
I would have to weld the valve to one of the factory tips dang
Wayne
1989 Silverado
Moderated by  MNSmith
