3 members (2-Ton, Steelonsteel, Donf), 108 guests, and 2 robots.
Topics128,034
Posts1,055,546
Members48,425
#1388009 12/12/2020 3:28 PM
Hello. New guy to the forum here. I have a 1962 C-10 that I have been performing a resto-mod on. I am installing a Ramjet 350 fuel injected motor and am looking for help on how to install the linkage from the petal to the throttle body. Wondering what anyone else has used to solve this one. Thanks.
1962 Chevy C-10
My Project Journal
Welcome Steve. Apparently asking hard questions. Our members are being real quiet. Try this question in the engine forum and see if that works better.
Hambone
~ HB
1962 Chevrolet C10
1962 Suburban
I have graphic of 8 cyl linkage. maybe a start.
~ HB
1962 Chevrolet C10
1962 Suburban
I would go to a wrecking yard and grab a throttle cable set up, (making sure to get whatever brackets & sleeves for it), from a 1990's Chevy throttle body truck and make it fit.
This is my son’s 1968. Holley 600CFM carb. Throttle linkage from pedal through firewall is similar to my 1965 C10 and likely yours too.
The Holley bracket only required a short piece of cable. Clevis goes on pedal arm and the rest hooks to the carb.
This info might not be what you’re looking for, but just maybe.
We use 80's, 90's Ford cables for two reasons: They take a round cable housing mount hole in the fire wall (much easier than the GM square hole) and they have a built in throttle return spring so no springs or brackets needed. The foot pedal is the floating type so no floor bracket needed.
Fire wall cable mount is at the 11:00 O'clock position to the brake booster:
[img]https://i.postimg.cc/V5x2yq0H/S10-053.jpg[/img]
Ford throttle cable with integral return spring is painted blue:
[img]https://i.postimg.cc/xqf3XcDT/S10-050.jpg[/img]
Evan
Thanks for the graphic. The only problem is the throttle connection is on the right side of the engine.
1962 Chevy C-10
My Project Journal
Great picture. Thanks but the connection to my throttle body is on the right side of the engine.
1962 Chevy C-10
My Project Journal
bsarts #1388322 12/14/2020 8:42 PM
Thanks I will have to look at that. I’m not concerned about the throttle body connections only the petal end.
1962 Chevy C-10
My Project Journal
A cable can run to the right, left, or to an engine mounted in the box. Just get a long housing, like a gas door release cable, and then use a hood release cable as they will last indefinitely. Long cable housing, long cable, cut to length and your home free. If your pocketbook is healthy then go with a Lokar.
Evan
Check out Lokar performance products. They have all kinds of cables,pedals,etc.
Steve, I just swapped tranny's from a worn out Hydramatic to a 700R4 on the backside of a 305V-6. I bought the Bow-Tie Overdrive setup and the bracket is designed for the Terry Cable system. I had to change from the old bell crank linkage to a new cable wire accelerator setup. I did a full tutorial on the swap using a gas pedal from a 2005-2009 full sized Ford/Mercury.
http://67-72chevytrucks.com/vboard/showthread.php?t=805290
Hope this helps.
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Thanks Modelman. Will have to check that out. Sure seems like ind solution.
1962 Chevy C-10
My Project Journal
