0 members (), 170 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
https://www.autobodytoolmart.com/product/champ-body-bed-cab-lifter-4053/champ-frame-equipment
First time I ran across this. Anyone use this? Thoughts?
Not sure this will lift high enough to lift off frame or install on frame...
Tom
1946 GMC Project
"Back-in-the-day Restore"
Just use a 2x6 with a thru bolt on the boom of the engine crane. A lot cheaper. That's what I used.
Post with Pic
I like that approach!
1946 GMC Project
I other approach is 4 buddies and a couple of beers. That worked for me on a number of occasions. Let me know if you need help. I am not smart but can lift my share. Spending much more time in New London these days and I have wanted an excuse/opportunity to drive your way.
~ HB
1962 Chevrolet C10
1962 Suburban
Crusty Old Sarge
Crusty Old Sarge
That's a nice setup but how often would you use it and as you said would it go high enough for your purpose?
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
The high enough isn't an issue, at least with my hoist. With my 2x6, dropping it down below the level of the rear of the hoist boom would be a bit of an issue (I didn't need to go that low to get mine on the rotisserie), but could be solved by adding a pivot point that was lower than the 2x6. Just fastening another chunk of 2x6 in a tee shape would do it. I relied on 2 buddies and a neighbor to set my cab on a pallet (which wouldn't fit between the legs of the engine hoist.)
Just grab a hold of it ahd lift it up. That's what I did. eeeek I did have two others help. They arn't that heavy when stripped down.
Moderated by  MNSmith
