0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 97 | Thought I'd post the results DYNO Forged 348ci Stock LS6 heads Stock LS6 intake Stock Throttle body Stock pulley Edelbrock 1 3/4 stepped 1 7/8 HVMC headers 223/228 @ .050 108/108 Stock 4L80E with Stock verter 8.5" 10 bolt with 3.73 (riveria wheels) Nitrous to follow: http://performancetrucks.net/forums/showthread.php?t=398925 | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Good curve. What changed between runs?? | | | | | Joined: Mar 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 97 | Did some air fuel changes and timing adjustments. It needs some more tweaking between 3k and 4k. I think I can fix that dip in torque. I'm also going to make some pulls starting at 1200rpm to get the bottom end of the curve fixed up. Since it's got a small verter in it (stock) I feel I should get that dialed in as well. I also have a couple other changes I'm going to make. I ported a stock throttle body last night and did some clean up as well as ordered an underdrive pulley. Once the motor is broken in fully I'll swap to a synthetic instead of the HD diesel oil I have in it now. I'm hoping to get it to 385rwhp and 375ftlbs. Then the fun begins with the bottle.
1963 Chevy P/U: Forged LS1/4L80E swap and big hit of N20 coming 1973 Camaro: Low compression solid roller LS1 with PT91 turbo Built for the Silver State classic 1967 Convert Continental: Stock Cruiser
| | | | | Joined: May 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 145 | That engine's making a ton of power. Was that at the rollers behind a 4L80e! Nice work! MV | | | | | Joined: Mar 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 97 | Yes those are numbers at the rear tires. I have a few changes I will be doing (more than likely after I get married and back from the honeymoon) but the goal is 385rwhp and 375ftlbs.
Right now I am running Delo (HD/Diesel oil) and I will be swaping to Mobil 1 synthetic.
I have a stock crank pulley which I bought a underdrive pulley and waiting for it to come in.
I had a second Throttle body which I just finished porting and filling a big void in it to help air flow.
I'm hoping that does the trick.
| | | | | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | Super 73 , What did you do for wiring,ecm ? I'm in the process of installing a 2006 6.0 w/4L80E in my 61 4x4 Burb and I'm undecided what to do with the harness .Buy a after market or retro the original please share your set up. Thanks 61 Suburban
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
| | | | | Joined: Mar 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 97 | We used a stock harness and removed the smog wires. If you go to LS1tech in the Hybrid section there is a ton of info there. Also, Performancetrucks.net is another great site. There is an older truck section under specialty vehicles. I go by LIL SS on both sites.
| | | | | Joined: Aug 2007 Posts: 23 New Guy | | New Guy Joined: Aug 2007 Posts: 23 | How come in neither run do the torque and hp curves cross at 5252RPM? And the crossovers occur at different RPM for the two tests? | | | | | Joined: Mar 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 97 | Kevin,
I did not notice this. I'm wondering if the tach was not reading right on the dyno. I'll be back there in 3 weeks after my honeymoon (getting married on Sunday). I need to swap out the Delo oil for synthetic, put on an underdrive pulley and a ported throttle body. I'm going to make 4 back to back pulls to see what kind of TQ/HP each one gives if any. So I'll take a closer look at the RPM when I am there again.
