1 members (Ole49GMC),
109
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 5 Junior Member | | Junior Member Joined: Feb 2007 Posts: 5 | I have a 69 c10 and have it stripped down to just frame and i am wanting to 1: put disc brakes on front and 2:put late model silverado rims on it. I have seen the brake conversion kits but have heard about using later model parts and retro fit it. On the wheels I have heard of spacers but also wondered about retro fitting with later model. If i retro fit (if possible) seems to be better i can kill 2 birds with one stone. any advice would be greatly appreciated... Also should i post this elsewhere?.....Thanks..Rick | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | many ways to do this, junkyard parts, a junkyard crossmember swap, high dollar disc brake kit. How late of Silverado, 5 lugs or 6? | | | | | Joined: Feb 2007 Posts: 5 Junior Member | | Junior Member Joined: Feb 2007 Posts: 5 | I have rims off of late model 6 lug rims and tires....it would be a shame if they dont work...Rick | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | Rick, They may not, it's my understanding that some of the late wheel offsets are much greater than on the early trucks. Fred
| | | | | Joined: Feb 2000 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 132 | define "late model". disc brakes that'll have 6 bolt rotors will be from the aftermarket OR you'll have to fab up some caliper mounts and use some slip-on rotors off the silverado (i haven't tried this yet)
i miss obscene phone calls...
| | | | | Joined: Feb 2000 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 132 | toomany,they'll be 4x4 though and it ain't gonna "bolt up" 2wd stuff is 5 bolt..
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Originally posted by tomslik: 2wd stuff is 5 bolt.. not since 99-six lugs for 2 & 4wd | | | | | Joined: Feb 2000 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 132 | yeah, but that crossmember ain't gonna unbolt;) kinda thought that's what the idea was...
