4 members (1955 1 Series, Otto Skorzeny, DaveV, Southerntruck), 78 guests, and 0 robots.
Topics128,115
Posts1,056,294
Members48,439
#138955 08/06/2007 3:22 PM
Junior Member
Junior Member
I have a 69 c10 and have it stripped down to just frame and i am wanting to 1: put disc brakes on front and 2:put late model silverado rims on it. I have seen the brake conversion kits but have heard about using later model parts and retro fit it. On the wheels I have heard of spacers but also wondered about retro fitting with later model. If i retro fit (if possible) seems to be better i can kill 2 birds with one stone. any advice would be greatly appreciated... Also should i post this elsewhere?.....Thanks..Rick
#138956 08/06/2007 3:26 PM
many ways to do this, junkyard parts, a junkyard crossmember swap, high dollar disc brake kit. How late of Silverado, 5 lugs or 6?
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#138957 08/06/2007 7:58 PM
Junior Member
Junior Member
I have rims off of late model 6 lug rims and tires....it would be a shame if they dont work...Rick
#138958 08/07/2007 4:54 AM
Rick,
They may not, it's my understanding that some of the late wheel offsets are much greater than on the early trucks.
Fred
#138960 08/07/2007 10:44 AM
define "late model".
disc brakes that'll have 6 bolt rotors will be from the aftermarket OR you'll have to fab up some caliper mounts and use some slip-on rotors off the silverado (i haven't tried this yet)
i miss obscene phone calls...
#138962 08/07/2007 11:00 PM
toomany,they'll be 4x4 though and it ain't gonna "bolt up"
2wd stuff is 5 bolt..
#138963 08/07/2007 11:17 PM
Quote
not since 99-six lugs for 2 & 4wd
#138964 08/10/2007 11:05 AM
yeah, but that crossmember ain't gonna unbolt;)
kinda thought that's what the idea was...
