Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (jay d, 2 invisible), 54 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
Page 2 of 2 1 2
dstray #1389208 12/20/2020 11:38 PM
So I have been doing some research on the motor (060I859F54Y). If Im correct it is a 1954 235 "blue flame 125" originally with a powerglide transmission. The head was not the desired 848 head, but instead it is the 3835913 model. If I'm wrong please correct me. Also is this a good motor? Ive heard rumors that the later 235 were better than the early 235? I'm glad to finally get conformation on what motor is in the old truck!
dstray #1389216 12/21/2020 12:02 AM
You are correct that an engine with number ending in F54Y is a '54 235, originally designated for use in a Powerglide equipped car, manufactured in the Flint, MI plant. The rated HP was 125, as you found. The engine has hydraulic valve lifters, if still in the original configuration, and not changed over the years. There is nothing wrong with the '913 head design. The combustion chamber is slightly larger than the later 848 head, which, if my memory serves me correctly, drops the compression ratio about a quarter, maybe half, point. So, not much difference in performance compared to the later 235s, and your engine's performance will depend more on state of tune and mechanical condition from a practical standpoint.
That engine should serve you well. Compared to the later blocks, it uses the older style water pump, which can be a benefit, since it positions the fan higher behind the radiator in the correct position. The block will have side motor mount locations, but I'm guessing the front cover has already been modified to use the front mount truck configuration, or exchanged with an older front mount cover, either of which work fine.
Motor on!
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
dstray #1389469 12/22/2020 8:28 PM
Dstray did I miss the value/asking price?
out here in California a running truck would be 8k to 12k seems in nice shape.
I paid 4500 for my complete not running 49 minimal rust 1949 3100
it came from Nebraska.
hope that helps , still interesting to see what they go for in different parts of country...
Merry Christmas everyone!
Page 2 of 2 1 2
