6 members (1955 1 Series, 53again, Cosmo, Hotrod Lincoln, mason86, Gray_Ghost), 100 guests, and 1 robot.
Topics128,068
Posts1,055,883
Members48,428
#1388241 12/14/2020 5:25 AM
Does anyone have the numbers for the bearings on a 1941 GMC cc101 half ton pickup? I could use all of them but I need the ones for sure for the center
carrier and the rear axle bearings. Thanks
Jeff LaCrone
Crusing in the Passing Lane
Jeff,
Which bearings, axle, crank, rod?
Ed
3B Offline
Hy Jeff LaCrone, not to rag on you, but you need to be a bit more precise in your questions so we can figure out what you are looking for. What are "fender carriers", do you want the outer axle bearing part numbers?
Sorry, voice to text got me again.
I am looking for all differential bearings. Center carrier, axle bearings outside by the backing plate and there are 2 on the pinion in the torque tube.
6 bearings with 4 different bearing numbers
It's for a 1941 GMC CC101. Chevy 1/2 ton is the same differential.
Thanks.
Jeff LaCrone
2 Offline
i don't vouch for accuracy, looking at parts books:
5.447 Bearing, Pinion Shaft Front
46-54 1/2 TON (ND 5306-T-1352 A BALL type) 905306 954394 954780
(also listed as New Departure number ND 5306-7-1352A in some books)
ND 5306 == SKF 5306
5.484 Bearing, Drive shaft pinion - Rear
46-52 PASS., 1/2 TON (Hyatt OR-1506 / Hy C-1506, roller type) 125630
5.536 Bearing, Differential Side
46-52 1/2 TON (Hyatt A 11445) (Hy 11445 Z) (18-rollers) 187434
5.855 Bearing - Race, axle shaft
40-52 1/2 TON RACE ASSY., outer w/ roller (Hyatt OR1502) 111121
Thanks alot!
Jeff LaCrone
Several of these bearings say 46 to 52. I believe the rear differential is the same as of 41? Does anybody know if that's a fact or not?
Jeff LaCrone
2 Offline
Oh my bad I probably found the wrong years
I’ll try to look again tomorrow
-s
2 Offline
assuming "COMM" means it's the 1/2 ton truck, then all the numbers are still the same as the earlier post, often there is no "1/2 ton" listed for 1941 year specifically
someone with more knowledge of the parts books abbreviations should comment
1940-42 ALL COMM., 1946-54 ALL 1/2 TON COMM. (ND 5306-T-1352 A BALL type) 905306 954394 954780
ND 5306 == SKF 5306
1935-42 PASS., COMM., (exc. EC,FC), 1946-52 PASS., 1/2 TON (Hyatt OR-1506 / Hy C-1506, roller type) 125630
1940-42 COMM., 1946-52 1/2 TON (Hyatt A 11445) (Hy 11445 Z) (18-rollers) 187434
1937-39 COMM., 1940-52 1/2 TON. RACE ASSY., outer w/ roller (Hyatt OR1502) 111121
-s
Commercial - COMM. = 1/2, 3/4 and 1 ton (3000 Series).
Utility - UTIL. = 1-1/2 and 2 ton (4000 & 6000 Series).
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Jeff LaCrone
