| | | Forums66 Topics128,068 Posts1,055,881 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2020 Posts: 13 'Bolter | | 'Bolter Joined: Apr 2020 Posts: 13 | Does anyone have the numbers for the bearings on a 1941 GMC cc101 half ton pickup? I could use all of them but I need the ones for sure for the center carrier and the rear axle bearings. Thanks
Jeff LaCrone
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Jeff,
Which bearings, axle, crank, rod?
Ed
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Jeff LaCrone, not to rag on you, but you need to be a bit more precise in your questions so we can figure out what you are looking for. What are "fender carriers", do you want the outer axle bearing part numbers? | | | | | Joined: Apr 2020 Posts: 13 'Bolter | | 'Bolter Joined: Apr 2020 Posts: 13 | Sorry, voice to text got me again. I am looking for all differential bearings. Center carrier, axle bearings outside by the backing plate and there are 2 on the pinion in the torque tube. 6 bearings with 4 different bearing numbers It's for a 1941 GMC CC101. Chevy 1/2 ton is the same differential. Thanks.
Jeff LaCrone
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | i don't vouch for accuracy, looking at parts books:
5.447 Bearing, Pinion Shaft Front 46-54 1/2 TON (ND 5306-T-1352 A BALL type) 905306 954394 954780 (also listed as New Departure number ND 5306-7-1352A in some books) ND 5306 == SKF 5306
5.484 Bearing, Drive shaft pinion - Rear 46-52 PASS., 1/2 TON (Hyatt OR-1506 / Hy C-1506, roller type) 125630
5.536 Bearing, Differential Side 46-52 1/2 TON (Hyatt A 11445) (Hy 11445 Z) (18-rollers) 187434
5.855 Bearing - Race, axle shaft 40-52 1/2 TON RACE ASSY., outer w/ roller (Hyatt OR1502) 111121 | | | | | Joined: Apr 2020 Posts: 13 'Bolter | | 'Bolter Joined: Apr 2020 Posts: 13 |
Jeff LaCrone
| | | | | Joined: Apr 2020 Posts: 13 'Bolter | | 'Bolter Joined: Apr 2020 Posts: 13 | Several of these bearings say 46 to 52. I believe the rear differential is the same as of 41? Does anybody know if that's a fact or not?
Jeff LaCrone
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | Oh my bad I probably found the wrong years I’ll try to look again tomorrow -s | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | assuming "COMM" means it's the 1/2 ton truck, then all the numbers are still the same as the earlier post, often there is no "1/2 ton" listed for 1941 year specifically someone with more knowledge of the parts books abbreviations should comment
5.447 Bearing, Pinion Shaft Front 1940-42 ALL COMM., 1946-54 ALL 1/2 TON COMM. (ND 5306-T-1352 A BALL type) 905306 954394 954780 (also listed as New Departure number ND 5306-7-1352A in some books) ND 5306 == SKF 5306
5.484 Bearing, Drive shaft pinion - Rear 1935-42 PASS., COMM., (exc. EC,FC), 1946-52 PASS., 1/2 TON (Hyatt OR-1506 / Hy C-1506, roller type) 125630
5.536 Bearing, Differential Side 1940-42 COMM., 1946-52 1/2 TON (Hyatt A 11445) (Hy 11445 Z) (18-rollers) 187434
5.855 Bearing - Race, axle shaft 1937-39 COMM., 1940-52 1/2 TON. RACE ASSY., outer w/ roller (Hyatt OR1502) 111121
-s | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Commercial - COMM. = 1/2, 3/4 and 1 ton (3000 Series). Utility - UTIL. = 1-1/2 and 2 ton (4000 & 6000 Series). Mike B  | | | | | Joined: Apr 2020 Posts: 13 'Bolter | | 'Bolter Joined: Apr 2020 Posts: 13 |
Jeff LaCrone
