2 members (baldeagle, dunfire), 86 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#1388038 12/12/2020 6:51 PM
Thoughts on using this flywheel. I bought from salvage yard. Safe? I have a 53 1/2 ton 235 engine.Thanks!
scottss60 #1388039 12/12/2020 6:55 PM
Unless you can machine that crack out, I wouldn't trust it.
scottss60 #1388046 12/12/2020 7:32 PM
If it was mine, I wouldn't use it. JMO.
Brian
1955.2 3100 Truck
scottss60 #1388052 12/12/2020 8:11 PM
The crack doesn't concern me as much as the possibility that there will be a bunch of hard spots from overheating of the clutch contact surface If you decide you must use that one, drill a 1/16" hole all the way through the flywheel at the end of the crack to keep it from spreading any further. Have a machine shop grind the friction surface smooth, and discard the flywheel if hardened areas show up. A hard spot is football-shaped, and what you're seeing on the surface is just the tip of the iceberg.
scottss60 #1388061 12/12/2020 9:50 PM
What concerns me more is what appears to be a crack shown in the area were the flywheel bolts to the crankshaft.
-David
1953 2-Ton GMC
scottss60 #1388072 12/12/2020 11:48 PM
Ditto to Davidbraley. Looks like a good paper weight. There are plenty of good ones out there if ya look around. Post a wanted ad here. I bet there are quite a few available.
scottss60 #1388073 12/12/2020 11:52 PM
I think it's past its' service life.
I have one available if you still need one.
DavidBraley #1388080 12/13/2020 12:46 AM
Yep, I missed that. Weld a piece of pipe to it and use it to support a bench grinder!
scottss60 #1388086 12/13/2020 1:28 AM
Didn't see that crack near the hub either. Boat anchor.
Hink #1388140 12/13/2020 2:54 PM
Yes. 6 volt. 139 teeth, 6 bolt holes, 9.5 inch clutch. For my 53 216.
Where are you and how much are you asking?
scottss60 #1388141 12/13/2020 2:54 PM
Hink #1388142 12/13/2020 2:55 PM
720 938 4908.
Thanks.
scottss60 #1388175 12/13/2020 7:18 PM
Hink, I do.
scottss60 #1388182 12/13/2020 8:20 PM
Offering to sell, buy or swap parts outside the Swap Meet Forums is against Stovebolt rules. Please take this conversation to PM or off-site. Thank you.
scottss60 #1439646 02/01/2022 1:57 AM
I think my question fits in with this thread so here goes. I’ve chased clutch chatter from my Apache for several years. I’ve tried a resurfaced flywheel and new clutch (temp fix -gone but came back), 2 piece rear main seal, new engine mounts all the way around. Several 3rd gear starts to get it hot (short term improvement).
So this winter I’m throwing the book at it. Engine out, new rope seal, new clutch and PP, and more but that’s off topic for now.
I’d go new flywheel but I can’t find a source of new production...anywhere. Plan B is then a used one from a ‘58 truck engine. It should be on it’s way soon to me so I’ll see how it looks in a week or so.
These pics are of my existing flywheel, my main questions are: are these circled spots the hard spots HRL refers to? And if I had this flywheel resurfaced the chatter would return? (as it did before).
If this used one coming in has similar spots - am I stuck with clutch chatter forever? Aside from going automatic- banish the thought.
'59 Apache
‘21 Beta 390RS
‘18 BMW R1200RT
'12 Ford Flex
'13 Aprilia Tuono
‘11 Ducati Hypermotard
Salisbury, MD
scottss60 #1440369 02/07/2022 8:21 PM
scotts60 How many have you heard tell of blowing out of there ?? Now if you put that behind a hot 283 at about 8000 rpm...you may learn !!!
Moonlight #1440370 02/07/2022 8:26 PM
Moonlight Have used flywheels that looked a lot worse than yours,clutch chatter can be elusive. Then you get around some piece of crap smooth as silk,so go figure !!
scottss60 #1440373 02/07/2022 9:04 PM
Yes, those are hard spots, caused by a slippy clutch overheating the friction surfaces. I've eliminated a lot of clutch chatter problems by replacing motor mounts. That one doesn't look too bad, but as the rest of the surface wears, the hard spots become high spots. A temporary fix can be had by refacing the flywheel with a surface grinder instead of a carbide cutting bit to get the hardened areas level with the rest of the friction face.
scottss60 #1441060 02/13/2022 6:29 PM
Well, the used flywheel came in and it’s quite the sight.
It looks like it sat in dirt for 27 years.
I’m having an experienced machinist friend take a stab at facing it.
Hopefully I’ll post an “after” picture of a useable flywheel. We’ll see.
'59 Apache
‘21 Beta 390RS
‘18 BMW R1200RT
'12 Ford Flex
'13 Aprilia Tuono
Salisbury, MD
scottss60 #1441062 02/13/2022 6:39 PM
If that one doesn't work, send me a PM.
scottss60 #1441063 02/13/2022 6:40 PM
Wow. Thats pretty pitted. If it dont work out, i have a few that are in much better shape.
scottss60 #1441079 02/13/2022 8:23 PM
Looks like a 11” clutch versus a 10” clutch flywheel, judging from your pictures.
They take a different pressure plate.
My Blog
scottss60 #1441110 02/14/2022 1:19 AM
Good call, I hadn’t thought that far ahead. I agree with you. Thanks for raising the topic.
'59 Apache
‘21 Beta 390RS
‘18 BMW R1200RT
'12 Ford Flex
'13 Aprilia Tuono
Salisbury, MD
scottss60 #1441369 02/16/2022 2:32 AM
The work on the flywheel turned out better than I expected. There was 0.030” taken off to clean it up, very reasonable. There are a few pits in it that didn’t come out but I don’t think they will present a problem long term.
I don’t see any cracks or hard spots, I was worried that the portion where the ring gear was most decayed might have damaged the wheel side, but there is just some spotty pitting. The shading in the picture is from the room lighting, the friction surface has an even consistent sheen.
I’m optimistic this flywheel will be part of the solution to my chatter.
Thanks to those who offered help if this didn’t work out.
'59 Apache
‘21 Beta 390RS
‘18 BMW R1200RT
'12 Ford Flex
'13 Aprilia Tuono
Salisbury, MD
scottss60 #1441388 02/16/2022 12:48 PM
Crusty Old Sarge
Crusty Old Sarge
Given the condition it started out as it cleaned up really well. Just wondering if once the pitting fills with clutch material if it will cause hot spots?
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
scottss60 #1441389 02/16/2022 12:52 PM
That flywheel is too nice to use. Might look really nice framed and hanging in the hallway.
1946 GMC Project
"Back-in-the-day Restore"
scottss60 #1441394 02/16/2022 1:48 PM
I have found that the larger the disc, the more chance of clutch chatter.
I would recommend still using a 10”. Disc with that setup.
I always tried to use the 9” clutch in all my customers vehicles to save them and me a lot of problems.
My Blog
