| | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2019 Posts: 13 'Bolter | | 'Bolter Joined: Apr 2019 Posts: 13 | Will a 55 bench seat work in a 51?
In my younger years I worried about the return on my principal now the older I get I worry about my principal being returned.
| | | | | Joined: Jan 2013 Posts: 2,234 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,234 | Please state 55 first series or second series and what ‘51 truck you are putting it in. The more info you give us, the better the answer you will get.
Chris | | | | | Joined: Apr 2019 Posts: 13 'Bolter | | 'Bolter Joined: Apr 2019 Posts: 13 | 55 is second series and the 51 is 3100 short bed.
Larry
| | | | | Joined: Oct 2005 Posts: 32 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 32 | No the 51 has a riser for the seat welded to the floor . The 55 second series mounts right to the floor . Will not work without modifying. Get you tape measure out before you do anything.
ppp
