2 members (RLB, Guitplayer),
139
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 55 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 55 | Hey all,
I'm wondering if a 6v horn relay will still work in a 12v conversion? I'm working on a 50 & 52 chevy trucks.
Thanks!
LOS ANGELES, CA
48 FLEETLINE AERO, 50 CANOPY EXPRESS
52 SUBURBAN, 57 BIG WINDOW Pickup, 64 Malibu CV
| | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | I installed a 12v relay. They are not expensive.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jul 2013 Posts: 55 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 55 | Its not a matter of cost. The question still stands. Will a 6v horn relay work in a 12v system?
LOS ANGELES, CA
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | That’s going to depend on the specific relay There are many manufacturers and variants Without more data all we can suggest is anecdotal experience. Since it’s not expensive to fail, try it and see Worst case it burns out or gets stuck on right?
I thought that there shouldn’t be a relay for the horn on that year so you won’t be risking an original part anyway One of my trucks is operating the 6v horn on 12 v directly to the horn switch in the steering wheel, I don’t use it much, but it’s lasted that way since the previous owner converted it many years ago -s | | | | | Joined: Jul 2013 Posts: 55 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 55 | I plan on installing original horns on two trucks. I have a couple of button style horn buttons that clamp to the steering column. I figured a horn relay would be required in doing this. My 48 chevy fleetline has this type of setup, but its a 6v system with stock Delco relay. I have an nos 6v Delco relay, but don't want to fry it in a trial an error test. I'd rather get the the proper guidance which is why I posed the question here. Is a relay not required? Why would they come stock on 48 chevy car and not on a 50 or 52 trucks? Did GM do away with the relay after a certain year?
Thanks!
LOS ANGELES, CA
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | In 1953, the truck horn changed to the “seashell” style horn (on the intake manifold)
That horn used a relay, as did the 6v “seashell” standard equipment 1954/55st 6v horn (and RPO/accessory dual seashell 6v horns) behind the front grill, mounted on the outside of the radiator frame. | | |
