1 members (joe apple),
110
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2020 Posts: 1 Moderated | | Moderated Joined: Dec 2020 Posts: 1 | Good evening , this is my 1st post, so hope it is i the correct spot . I am starting on a 66 C30 panel with a 292 in it . I am going to pull the motor and trans to do the engine compartment , so I want to check out the engine. It runs and drives but blows a bit of oil, I dont know if its just valve seals or what yet. I read the cylinder diameter is 3.88 inches or 98.55 mm . if I dont have to have the motor bored , I won't . I dont see the point . I can hone the cylinders and do a re ring and bearings etc . My questions are , does anyone know what a reasonable compression check should show? and also what tolerances do I have for that cylinder diameter before it needs a re bore ? Thanks Very much, Bob | | | | | Joined: Nov 2014 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 70 | You should have at least 100 PSI of compression on each cylinder with no more than a 10% variance between cylinders. As far as cylinder wear you will find that the amount of taper and out of roundness will be the problem. Any cylinder with more than 5 thousands of out round will need to be bored. I am not sure what the spec is for taper.
ESum
| | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | Taper wear in a cylinder is not linear- - - -most of it happens at the top, in the first 1-2 inches of piston travel. At 2000 RPM, a ring is expanding and contracting 60 times a second, trying to stay in contact with the cylinder wall. That makes for very short ring life if the taper wear is more than .005". Boring a worn cylinder eliminates the taper and takes a lot of stress off the rings. Out-of-round isn't nearly as critical as taper, but neither one is a good thing. Jerry
