3 members (baldeagle, Jon G, Peggy M), 241 guests, and 5 robots.
Topics128,106
Posts1,056,214
Members48,436
#1386640 12/01/2020 12:48 AM
Anybody ever try super singles instead of duals? Looking for axle ideas. On a 57 3600
Crusing in the Passing Lane
I recently did some checking on super singles(22-5’s) and they were prohibitively expensive($1,200. ) and had 200 plies or so for concrete trucks, etc. Decided against that.
10 and 12 by 16,5 tires used to be used for the but they have become out of favor for years.
Decided to stick with duals.
Ed
In what sort of fantasy world does a 3/4 ton truck have dual rear wheels?
Jerry, believe it or don't, some people even put duals on Suburbans. Why, I'll never know.
Jerry, I'm new to this, correct me if I'm wrong but looking up the vin and title, everything shows to be a 3/4 ton truck. Vin starts with 3E indicating a 3600, 3/4 ton correct? Did someone potentially throw a 1 ton dually rear under it?
Trich,
Yes, 3E indicates a 3600 truck. According to the GMheritage center docs there was a dual wheel option for 1957 3600 trucks. To verify that yours was equipped from the factory with duals, check the GVW rating. A GVW of 6900 lbs. should indicate dual wheels. Also, you may want to check the wheelbase: 3600s had a 123.25" wheelbase, while the 3800s had a 135.0" wheelbase.
I don't know a whole lot about these trucks, but I do own a 1957 3600, a 1956 3800, and a 1959 3800.
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
Oldbolter,
Yes my gvw is 6900lbs and is 123.25
Cool. Your truck is, in my opinion, a fairly rare truck. Please post pics. I would love to see your truck.
Oldbolter
Yea it seems rare, I can't seem to find much info on them. I just picked it up over the weekend. Needs a total rehab. It will be my first. I have a lot of ideas in my head, but now that your thinking its a fairly rare truck, maybe I should keep it all original. I'll snap some pictures tomorrow
Do you have a pickup-type bed, or is there a flat bed installed? Duals under a pickup bed would require some pretty creative fender modifications, even if it was a factory option.
ed. I have an 8' step side bed on my radar that I'm gonna fab up. A traditional pick up style bed wasn't an option with the duals, that I've ever seen
I've seen pickup fenders split down the middle and a piece of sheet metal about 6" wide added to cover dual wheels. It works, but it makes the truck look a little funny.
I think it would look badass. It’s possible with adaptors. I don’t know whose truck this is, found pics online but appears to be an 8 lug to 10 lug semi rims adaptors. Wheels and tires would be extremely expensive new but there are tons of used on eBay.
In at least some states, that setup would be a traffic ticket magnet- - - - -tires that stick out past the fenders without at least a rubber flare covering them present a foreign object hazard to nearby vehicles. There's something about getting a rock thrown from a tire tread through a windshield that doesn't impress most people!
Tony, yes thats what I'm looking to do. I have a lead on the rears already. I dont know if there's a company out there that make the 8 lug to 10 lug adapters, that match our bolt pattern. I know they're out there for the newer models.
Jerry, I plan to piece fenders together to make them wide enough to cover tire
If your 3/4 ton is 8x6.5 then there are lots of adaptors out there.
Fox Offline
How about this?
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
It was rather common to buy a vehicle in the 1950's and then try to haul more with it than it was designed for. There were adapters sold in the 1950s and 60s to make dual wheels out of singles. They used the regular wheels that were designed for singles and you had to remove the outside wheel to check the air on the inside tire. Quite often they removed the fender all together or made one out of an old barrel. On a flatbed it didn't make any difference. I run singles on my bulk hauling fleet. 445/50R22.5 on aluminum hub piloted. It would take quite a bit of horse power just to turn them. As for the cost, $1,200 is list. I buy them for considerably less on my Michelin national account.
https://photos.app.goo.gl/2Nc2RCZ4gKu1niXH6
It slipped my mind to take weight/power consideration. What does a super single weigh on average?
Michelin advertises a drive tire 445/50R22.5 on an aluminum wheel at 248 lbs. Trailer tires weight a few pounds less because they have less tread depth. Here is the Michelin brochure.
https://photos.app.goo.gl/qYsPsgT42aXBoeWV9
