0 members (), 160 guests, and 5 robots.
Topics128,149
Posts1,056,818
Members48,456
Does anyone have any pictures showing the position of the fill hole?
Sir Searchalot
Sir Searchalot
Passenger side housing in front of axle .....Recessed, filled with gunk. Dig it out.
If it's the o.e. vintage it should have a round cover on the rear (drop out 3rd member), fill plug is in cover. if something else, post pic.
BC
1960 C60 pasture art
Sir Searchalot
Sir Searchalot
I didn't mention that because I assumed that plug would be obvious if present. I should not assume, I suppose.
Yes that is what I have. What I need to know is what "clock " position does the hole go? Is it above center or below center, etc.[img]https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/25179/filename/differential cover pic.jpg[/img]
Sir Searchalot
Sir Searchalot
I'm saying below center.
Agree, as evidenced by the lube leaking out of the vent on ole green's picture. With the fill plug above center it's overfilled. Probably leaking out the wheel seals as well.
[img]https://www.stovebolt.com/ubbthread...r/25196/filename/20201201_141547_001.jpg[/img] this is on my 49 1 ton. Lower than horizontal centerline. Left of vertical centerline
1949 gmc 1-ton
That will make it leak for sure, plug below center would be correct.
BC
Thanks everyone.
Riding in the Passing Lane
The cover is on upside down.
George
1972 Chevy c10 Cheyenne Super
