4 members (38Kiwi, UtahYork, dt235sd, Hotrod Lincoln), 123 guests, and 2 robots.
Topics128,196
Posts1,057,390
Members48,471
2 Offline
Saw this tachometer on eBay
Post implies original equipment
Photos aren’t the best
Is this an original part for a 1953 truck?
https://www.ebay.com/itm/1947-1953-GMC-Truck-0-3500-RPM-Tachometer/124450092248?hash=item1cf9cdb4d8:g:yZYAAOSwaspfuBPu
Not sure I want to pay that much to find out
But it looks neato
-s
Curmudgeon
Curmudgeon
Oh Cool!
Wild guess maybe an original commercial diesel truck like the 630?
It's driven by a cable so maybe it was connected to the distributor or the generator.
I could only find an example from a 1957 GMC 630.
the low rpm range certainly suggests a diesel.
Agree it's in diesel rpm range. But could also be stovebolt range. Isn't 3000-3500 the working range for a stovebolt engine?
RR
RonR
1970 340 Duster
1964 CJ5
thats the useful rpm range for sure, but if i recall correctly the redline for a 6-cyl of that era is around 4200. i figure the tach for a gasoline stovebolt would run up to 4500. but i'm speculating.
Curmudgeon
Curmudgeon
Graph
Crusing in the Passing Lane
My 630 has a dash mount location for one.
Ed
Curmudgeon
Curmudgeon
The seller said he bought a group of parts to get the parts he wanted.
I recall reading that a 216 engine redlined somewhere around 3,200 and a full pressure 235/261 redlined somewhere around 3,800-4,200, but can't seem to put my fingers on that documentation.
I never hesitate to put the gas pedal down hard on my 261 in traffic, but I highly doubt I have ever exceeded 3,000 rpms with it.
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
