2 members (Otto Skorzeny, 1 invisible), 269 guests, and 1 robot.
Topics128,079
Posts1,056,058
Members48,433
#1386178 11/27/2020 5:25 PM
I’ve got a 47 Chevy panel. When driving the door windows roll down about 3”. I’ve got some ideas to address this but was curious to hear everyone’s ideas as to how to best fix this. Thanks in advance for the tips! David
1949 Chev 3800
Prime suspect......the spring ( black in the pic) on the window regulator is broken or missing.
Didn’t think of that! Thanks Showkey!
1949 Chev 3800
Rubi, if you pull the regulator out and find that big external spring is broken, as Shopkey implies, absolutely replace it. If that external spring is not broken then your real problem is inside the regulator. There is another internal spring which you will find is broken (the small tab on the end of the spring). My first picture shows the reassembled regulator but note I’ve rebuilt it with the housing held together with nyloc lock nuts. You are going to have to get creative (wear safety glasses) and drill out the original rivets holding the housing together to gain access to the real internal problem. The next picture shows the replacement internal spring, about the diameter of a quarter.
Classic Parts, (1947-54) Window Regulator Spring Item Number 18-781. $3.95 each
Good Luck. Dave
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
