2 members (Charles in CA, Otto Skorzeny), 310 guests, and 7 robots.
Topics128,078
Posts1,056,031
Members48,433
#1386089 11/26/2020 11:34 PM
Im using after market hinges ( Classic Parts ) on my 55 Cameo and although they are as low as possible on firewall the hood sits high when I close it but goes to perfect height if I push it down at the cowl . Has anyone else had this problem and how did you correct it ?
Crusing in the Passing Lane
Is the new hinge well lubricated, might be tight from new assembly. Lube it well and exercise it.
Ed
will try that thx . does not seam tight though
If you still have the factory originals, Willie Wilson does a nice job in refurbishing the stock ones..
http://www.hoodhingerepair.com/
