3 members (2-Ton, carbking, Guitplayer), 291 guests, and 0 robots.
Topics128,089
Posts1,056,141
Members48,436
#1385757 11/24/2020 7:25 PM
1956 Chevrolet 6100
How do you remove the outer bearing race? I have read in the shop manual that you need to remove a snap ring then drive the race from the outside of the hub to the inside. How do you get it out? Any tricks to this?
Suggestions are welcome. Thanks
Tap bearing race towards outside (away from snap ring, remove snap ring. Use a punch or soft drift to knock race out backside of hub.
BC
1960 C60 pasture art
After you have tapped the race away from the snap ring, use an internal snap ring pliers with right angle tips that fit the holes in the ends of the snap ring.
Similar to these: https://www.zoro.com/knipex-6-34-pr...0Mb8-ol5YoHkktvO7kavuFo_a_xoCM0oQAvD_BwE
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
Thanks. I wasn't sure if regular snap ring plies would do the the job or if I needed some special tool.
These pliers are stronger, work better and cost less, especially if you grind the tips to fit the holes in the snap ring.
https://www.ebay.com/itm/11-Long-90-Degree-Needle-Nose-Pliers-Extra-long-Reach-and-Polished-Finish/290699339018?hash=item43af07e50a:g:xFAAAOSwYENcnPh9
Some snap rings don't have holes in them, they may have a tapered end that you hook a thin screwdriver under and pry them out or you may need to hook a 90* pick under it to get it started.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Not to highjack this thread. But does anyone know how the inner race of the inner bearing comes off the axle? Switching over to tapered roller bearings and i need to get them removed.
THE BLACK VIKING
1958 Viking 60 ~ my new toy hauler
My Current fleet: 1954 chevy 3800, 1953/4 gmc 450 coleman 4x4, 1956 chevy pickup, 1958 Viking 60
Keep 'em rollin fellas!
Black Viking
What year and type of axle are you working with ?
If you are talking about this in the picture, I just grabbed mine and pulled it off.
Noonan its the part that doug pictured. Mines a 58 viking 60 2 speed chevrolet axle
THE BLACK VIKING
I never even tried that they looked almost pressed on so i was worried but ill try and just pull it off thanks!
THE BLACK VIKING
If it's stuck tight with congealed grease, just warm the race up with a Propane torch and grab it with a welder's glove- - - -it will slip right off.
