5 members (Peggy M, Gdads51, KEVINSKI, Otto Skorzeny, 1 invisible), 186 guests, and 2 robots.
Topics128,081
Posts1,056,069
Members48,434
I finally recieved the rear quarter patches that I ordered (I ended up with 2 1/2 sets) for my 67 Suburban.
I intend on putting on the lower chrome trim pieces at some time, so my thoughts are to hide my "body work" behind them.
I am thinking about cutting out the rust just below the body line and up around the reverse light hole.
Thank you for your thoughts.
Another quality post.
Real Trucks Rattle
Hiding the butt joint behind the trim wouldn't be a bad idea, IMO. But I'm not an expert by any means. You'll at least want to put the joint where you can get to the back side to planish the welds.
If he doesn't weigh in soon, shoot a PM to MPandC. Robert will probably have the best advice for you.
Sir Searchalot
Sir Searchalot
Yes leave the body line alone.
I know the following will get a chilly reception from many. But, I've been happy with a couple of similar projects completed by flanging and 3M panel bond. Welding is something I have some experience with but I gave panel bond a try (out of curiosity as much as anything) on a job that would have required about 50" of butt weld and was/am happy with the results 10 years later.
Good Luck,
RR
RonR
1970 340 Duster
1964 CJ5
Sir Searchalot
Sir Searchalot
The procedure for an area like shown with thin metal welding depends on if there is access to the back side.
Rusty, I am assuming you are going to MIG this?
Agree with Kevin that the black and aluminum trim will cover the weld area. So less practice is required smile
Unless I go way deeper in to the truck than I want to, there is no access to the back side of the panel in that area.
I'll be using a small mig machine. I used it on my 36 international cab and fenders. I'm not a good welder, but I can surely wear out a grinder!
I'm also considering using a roll on bed liner under the trim as well then painting it the same color as the rest of the body (white at this time).
Real Trucks Rattle
The condition of the metal will determine how much you'll end up cutting off.
You'll need good clean metal to weld to.
Sounds like your plan is doable
Im no expert, only did this one time. I cut a little higher than I need to. Next time Ill try to keep as much original metal as possible.
Good luck
I seems pretty solid along the body line, which is where I'll start cutting... If I mess it up, I have a another patch panel in hand!
Real Trucks Rattle
Sounds good
If it looks iffy once you open her up consider treating the back side areas with rust converter. Weld thru primer in the area around your seam
You'll know once you strike your first arc if you have good metal
My welds were bird poop welds. The flap disc was my good friend
thumbs_up
Dads50, I'll definitely be working out the rust as I dig into it.
I wanted to pull the mouse pee stunk up plywood out, but at the moment i'll have to deal with it until I'm in a better place.
Real Trucks Rattle
As many have found out, the rust you see from the outside is like the tip of an iceberg, more lurking beneath ready to pop through in a couple years. For deep pits that have not yet broken through, on bare steel these can many times be seen as a darker grey (as compared to bare sheet metal color) circle about 1/16 to 1/8 diameter. This is why it's a good idea to strip to bare metal when doing such repairs, it lets you see such tell tale signs before applying the liquid gold (paint). Another tool good for testing the structural soundness of the sheet metal is an old ice pick. Any areas like you show on your quarter, I would test around those rust areas to see exactly how far the rust goes. The ice pick will find pits that are coming through from the back side. You want to find these now, as they are cheaper to fix before the paint goes on.
Many people will tell you to use as little of the patch panel as possible. On forums like this and many others, you almost hear it so much that it seems a priority. I could care less about how little of a patch you can use, that should be the last consideration. For me, testing with an ice pick is the first step to identify any hidden damage. As far as trimming, first and foremost it should be in an area that is accessible from the back side for using a hammer and dolly to planish (stretch) the weld dots to remove the shrinking (warping) that occurs naturally as a weld cools. Other factors that help will be to use a body line/crease to help control the distortion. Stay out of flat areas (like the mid line of a quarter panel or door) as much as possible, as the low crown area has less "support"....it's easy to lose it and more difficult to restore it once gone. If damage is sufficient that a small patch is not large enough, rather than use a "half quarter" that puts the seam in a flat area, spend the extra for a more full quarter that puts the seam up higher in an area that has a high crown (more radius) as this is similar to the body lines in that it does a better job in helping to control the distortion. A weld seam by such a crease should be 3/4" to 1" away, to allow room for using a dolly on the back side without banging up the crease. If your patch is indeed large enough to cover all the damage, put your seam about an inch from either side of that body line. If the crease is inaccurate, you may want the seam on the bottom side. If your panel has a bit more rust nearby that area, then put it above the crease. If the crease is not sharp enough or is too sharp (seen both), these issues can easily be addressed before the panel goes on, so that it will match up better next to the original metal.
Butt welds please. If you are using a flanged/stepped seam in either spot welding, full welding, or panel adhesives, be forewarned that you have a good likelihood of a ghost line appearing in your paint, showing exactly where the seam is located. Sure, the OEM's are using body adhesives all the time. What they are NOT doing is using it to add a seam down through the middle of a door or quarter panel where is needs to be an invisible seam, as we are trying to do in installing repair patches. The Welding tips and tricks "sticky" at the top of the Paint and Body forum is a good read that covers most of these details.. The following video shows a ghost line in the paint of a wagon's tailgate, using a flanged repair. You can also see where the holes from the clecos were welded shut. This was done by the owner, and the only place in his restoration that he didn't use a butt weld. A darn shame because it was very nicely done except this one area. He graciously allowed me to film it to use as a learning tool for others..
Thanks for the info MP&C!
Real Trucks Rattle
