3 members (moparguy, texas46, Gray_Ghost), 191 guests, and 3 robots.
Topics128,108
Posts1,056,236
Members48,437
I need help finding the vent window rubber for my 48 suburban. I can only find for a 51. Will this fit? Where can I find a set to stop the tsunami. Lol
I also need the 2 metal straps for the side wall cards.
Thank
Mark
Mark,
1951 was the first year for the front door vent window?
I think (I am pretty sure) that the vent window glass was the same from 1951-1955st trucks (on both Chevrolet and GMC cab trucks).
Good luck finding those “metal straps” - those probably disappeared when the cardboard deteriorated? Do you you have the metal-surrounds and the vertical metal bars/strips?.
Post a Parts Wanted in the Swap Meet.
No wonder you're having trouble finding 48 vent window rubber: 48 didn't have vent windows. If your truck has vent windows, the doors are not original 48. More likely your doors are 51-54. So yes, the 51 vent rubbers will work on your "48."
For the metal strips for the sidewall cards, check MNSmith's build thread. He fabricated some.
https://www.stovebolt.com/ubbthread...suburban-update-mnsmith.html#Post1280468
1951 Chevy Panel Truck
I would guess 1951 doors because they would work with the '51 and earlier strikers.
Good point.
