| | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2020 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2020 Posts: 25 | I need help finding the vent window rubber for my 48 suburban. I can only find for a 51. Will this fit? Where can I find a set to stop the tsunami. Lol
I also need the 2 metal straps for the side wall cards.
Thank Mark | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Mark,
1951 was the first year for the front door vent window?
I think (I am pretty sure) that the vent window glass was the same from 1951-1955st trucks (on both Chevrolet and GMC cab trucks).
Good luck finding those “metal straps” - those probably disappeared when the cardboard deteriorated? Do you you have the metal-surrounds and the vertical metal bars/strips?.
Post a Parts Wanted in the Swap Meet. | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | No wonder you're having trouble finding 48 vent window rubber: 48 didn't have vent windows. If your truck has vent windows, the doors are not original 48. More likely your doors are 51-54. So yes, the 51 vent rubbers will work on your "48." For the metal strips for the sidewall cards, check MNSmith's build thread. He fabricated some. https://www.stovebolt.com/ubbthread...suburban-update-mnsmith.html#Post1280468
1951 Chevy Panel Truck
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | I would guess 1951 doors because they would work with the '51 and earlier strikers. | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | I would guess 1951 doors because they would work with the '51 and earlier strikers. Good point.
