8 members (Peggy M, Donf, Otto Skorzeny, Wickedbass, Hawkman, NJC, GRNHydra, hdgeren), 83 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#138500 06/24/2007 3:25 PM
I'm getting ready to weld in the new motor mount perches and need to know should I center the motor or should it be offset to one side. If offset, how much. Also, what about the transmission. Should the output be centered if the motor is offset or should it be offset as well.
#138501 06/24/2007 4:21 PM
The only reason you would want to offset the motor is for clearance reasons. If you CAN put the motor dead center, than do it.
But before you weld those mounts, have you bolted on the exhaust manifolds, the steering, the radiator with the fan on the motor>
You really need to "mock" it up. My brother recently did a Model A where the motor was all installed and set up and the guy was having him finish up the car. The guy apparently never set up the motor with the water pump on! There was NO room for any pulleys!!!
Trial fitting parts is time VERY well spent.
Brian
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
