Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (Joe W, Wayne67vert, baldeagle, Hotrod Lincoln), 66 guests, and 3 robots.
Topics128,005
Posts1,055,254
Members48,418
Page 1 of 3 1 2 3
#1382052 10/24/2020 2:20 PM
Chaz71 started his Journal in the DITY Gallery here.
It all started in the Welcome Center here.
hi gang, haven't been on here for few yrs. still working on the apache .
hope everyone is good. will be posting pics soon of where I'm at.
Been away because of life. lol
thanks
1961 apache
Here are some pics
1961 apache
Work on the frame
1961 apache
got a 4 speed saginaw at a swap meet yrs back. opened it and looks brand new inside. put mopar shifter to it
1961 apache
Unconventional Thinker
Keep 'em coming.
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
I will do my best sir. I drive a mixer and we’re very busy.
Thanks for looking.
1961 apache
OK. Installed k frame (mopar term don't know GM's term). It’s bolted not welded like todays. Torsion bar, just not put in yet.
Also removed right side trailing arm.
1961 apache
new parts for right side trailing arm and spring holders. got the bushing out. starting to clean up parts. springs are good and the amount of driving I'm gonna do they are r fine.
my pics and steps are in no order. its when/where i can work on her.
1961 apache
cleaned up passenger side and painted
1961 apache
ok . right side is done. now the next part should be fun. lol
1961 apache
not much done this week but started cleaning and removed break lines and pan bar . i know the rear is good. i ran the the truck for a while before tear down.
1961 apache
now, what to do? wanted to know what's inside. one legger and I'm guessing it's the small rear. going to think on it for a while.
1961 apache
not much done this week. but did install torsion plate to frame . starting on the a arms.
1961 apache
ok , well the rear end is not working out. it's a good rear. i drove it around for awhile before tearing truck down. can't get parts for it. i would like posi. so im going to ponder on this for awhile.
Anyway, started working on frame. Put the upper a arms on. getting ready for lower ones.
1961 apache
ok . back to the rear. pondering is over.
road trip today. Picked up 12 bolt rear with 3.73 posi . i hafta put new axle pads on it because of their different spaces from each other.
1961 apache
pulled the axles. took out seals and put news ones in. removed brakes . waiting on new ones.
1961 apache
One side now done. New brakes wheel cylinders and put axle back in.
1961 apache
Other side now done. brakes finished axles back in . New pinion seal in.
Now onto the axle pads.
1961 apache
took off axle pads and tacked new ones on.
1961 apache
so the rear axle is on hold for a bit. i hafta move axle from spot to another to finish welding pads on. i bolted the lower a arms on and one torsion bar in.
1961 apache
i have ben waiting for a chance to move the axle from the tool room to other side of garage . tool room has small mig welder . arc welder on others side of garage. So between snow clearing, drying off walks, driveway, took axle off the blocks put on handtruck (one man show here) and moved it.
finished wlding axle pads with arc welder. then moved it to the other garage, which i call the tee pee cause thats where the apache is. Lol.
so good progress.
1961 apache
now both torsion bars are in. Slow progress lately.
1961 apache
some parts ready. Some new parts and !! got the rear end in!!! yay !!!
good weekend!
1961 apache
had to do some work on my other rides non-stovebolts.
Van got painted. tuning stationwagon .
hoping to get some work dun on the Apache.
weather is breaking and that means crazy work hours and yard work. lol
1961 apache
alright! got the rear end painted . also mounted front shocks and a arm. rubber bumpers - they were harder putting on than the rear . lol
1961 apache
been awhile. work . throat cancer treatments. slowly at it again.
1961 apache
New bushings for pan. hard bar
1961 apache
starting on rear fender
1961 apache
(Moved several threads into this one .. Running several different threads in the Project Journals about the same vehicle is confusing. Have one build journal.)
I see the 1961 Apache in your signature line but your username has 71 in it, so could indicate a separate vehicle.
Looks like you are making good progress, keep up the good work.
Tore the e brake down, ordered new cable cleaning up.
1961 apache
installed new adjustable panhard bar
(No picture with this one. Pix came from Chaz's C-drive ~ Peggy)
1961 apache
Pictures of my e brake system from a 61 apache.
1961 apache
Man of few words are ya! chug
This the e brake system in the frame.
1961 apache
E brake cables to the rear and showing how the sit. Front cable not hooked up yet that will be when cab is on.
1961 apache
A new panhard bar also starting on disc brakes.
1961 apache
Set the air shocks in place and started runing the brake lines.
1961 apache
Installed the lines for the air shocks, and made sure the air valve was nice and tight. Packed the new bearings and put front hubs on.
1961 apache
Chaz,
Those rear springs? Something does not look right. My sense sez they should be much more robust. Did they come with the truck or are they aftermarket and part of the air system you are working?
I may be wrong but they are different enough that I thought I needed to mention.
~ HB
1962 Chevrolet C10
1962 Suburban
Thanks hambone I have the shocks most of the way out, once I get everything in place, wheels, on the ground I will adjust the shocks. Disc brake kit was a joy to put on, cpp awesome company.
1961 apache
Page 1 of 3 1 2 3
Moderated by  Phak1
