8 members (Otto Skorzeny, TUTS 59, Bill Hanlon, Rusty Heaps, Southerntruck, DaveV, TexasA&M48Truck, Peggy M),
274
Mod | | | Forums66 Topics128,078 Posts1,056,044 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 30 | I need to replace the oil in my front differential and in the transfer case of my truck (1961 K10 Pickup). The manual calls for straight 90W gear oil, but it's proving to be hard to find. Are there suitable / recommended alternatives?
Lots of hits saying that 80-W90 is the same, but others saying to stay away.
Thanks!
- troy
1961 Chevrolet K10
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Tractor Supply Co. 90 weight Ford tractor transmission oil is a direct replacement for the straight mineral oil specified for the transmission and transfer case. It does not have the hypoid additives that supposedly attack brass synchronizer rings. Jerry
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | My NAPA also gets it for me, but it is not in the store. | | | | | Joined: Aug 2002 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 30 | Thanks - I have a Tractor Supply close by and I'll go check there. Much appreciated!
1961 Chevrolet K10
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Do not use the straight mineral oil in the rear ends. They must have GL-5 gear lube. 80-90 will work fine. George
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Ditto- - - -the straight 90 mineral gear oil is for transmissions and transfer cases only. Jerry
| | | | | Joined: Feb 2019 Posts: 4,479 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,479 | I’m glad I read allot of these post, otherwise I wouldn’t know I just screwed up and just installed straight 90 weight mineral oil in the rear end. Fortunately I have not driven it yet as I still need to install my engine.
Do I need to flush it out or is draining sufficient?
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Aug 2018 Posts: 351 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 351 | Phil, just a drain and change is all you need.
Doug | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | The difference is in the design of the gears. They're called "hypoid gears". The pinion gear in a drive axle is below the centerline of the ring gear, and the teeth mesh with a shearing action that requires a high pressure lubricant. The hypoid additives in some gear lubes supposedly can damage brass synchronizer rings. A rebuilding depot for Fuller Road Ranger transmissions that I used to do business with in San Francisco had 55-gallon barrels full of scrap synchronizer rings with heavy black deposits on them, and the manager of the facility told me they came out of transmissions that had been running "multi-purpose" gear lube with hypoid additives in them. https://www.motioncontroltips.com/hypoid-gearboxes-what-are-they-and-where-are-they-used/Jerry
| | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | Since we are talking about rear axle lubricant... If the rear end has a "positraction differential lubricant only" tag, you are supposed to put in an additive. Is the additive strictly necessary? What does the additive do?
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | The additive prevents, or at least reduces the tendency for the limited slip clutches to grab and chatter in low speed turns. Without it, some types of locking rear ends have a noticeable shudder in turns unless enough throttle is applied to make the clutches engage fully. On dry pavement with good tire traction, limited slip axles can get pretty noisy in tight, low speed turns without the additive. Jerry
| | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 |  Thanks!
