| | | Forums66 Topics128,050 Posts1,055,670 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 224 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 224 | I have a ‘47 AD 3100 that finally is nearing the finish line. It was to be “finished” in September but it’s a long story. Everything is painted except for the hood. The exterior is a no brained. It’s the inside that I need some advice. I’m sure someone has dealt with this over the years. The inside of the hood (underside) was sprayed with sound deadener/undercoating. I do not intend to wash/scrape this coating off. I’d like to simply paint over the undercoating with single stage enamel to make it Mariner Blue. I’m questioning the adhesion of the paint to undercoating considering the engine heat generated. Certainly an option would be to add more undercoating to cover any overspray after the paint is dry. Just trying to work smarter not harder. Any experiences, opinions are greatly appreciated. | | | | | Joined: May 2015 Posts: 11,029 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,029 | I think paint over undercoating would eventually peel off. Originally the underside of the hood was not painted. Mine is black primer with some Omaha Orange overspray. But if you want to paint the underside of the hood that's OK too. I would pressure wash it to get loose stuff off and then shoot a coat of some sort of primer before your topcoat. Dust and/or grease will definitely need to be removed. I don't think underhood heat will necessarily be a problem. It may last long enough for your needs, but expect the paint to come off in spots. If you're just trying to pretty it up a bit and don't need the body color, I'd just shoot a good quality undercoating over what's already there. It's rubberized and will probably stick better than paint.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | You can get Truck bed liner in colors. The blue might be close enough to blend in with Mariner Blue.
