8 members (Hanks custodian, FAST55, Rusted Nut, Otto Skorzeny, Gdads51, Bill Hanlon, TexasA&M48Truck, John L.), 82 guests, and 3 robots.
Topics128,075
Posts1,056,003
Members48,433
#1383906 11/09/2020 1:58 AM
These 2 numbers are stamped on drivers side
of block , about dead center, on a 3769716.
1960 C20 Platform
dbwr #1383934 11/09/2020 12:59 PM
Block casting code (3769716) on a 1958-1962 235 truck engines and some car engine.
Find and post the block casting date, and the head casting code and date. That might better ID the engine?
locations of codes
dbwr #1384163 11/11/2020 4:17 PM
OK. I get that it is June 10, 1960
was just curious about the 17
1960 C20 Platform
dbwr #1384170 11/11/2020 6:32 PM
Just spitballing here, but may just be a code for the pattern used for that particular head casting. I'm sure there wasn't just one pattern for all the 3769716 heads.
dbwr #1384212 11/12/2020 2:21 AM
Sir Searchalot
Sir Searchalot
As Kevin indicates, I would agree and say the 17 is the mold/pattern number and 716 is possible foundry code. OR vise versa because 716 is the last three numbers of the casting number. These were for traceability in case of failures/issues and quality control inspection recording. (mold wear)
Cast numbers with screw head or button head on either side indicates changeable inserts, called tags, attached to the pattern, in a built in recesses. These can include cast dates, pattern number, molding line conveyor (shaker), pointer and casting numbers. Some hardly changed, and they were soldered on. When you see a number like GM3, that is a pattern number. If this head or block has a GMX number, then the 17 and/or 716 must be something else.
GM had various ways of delineating the shift.
The shape of the screw heads on the ends of the casting date tag was: two flat head for 1st shift, one flat head and one round head for 2nd shift and two round for the very rare 3rd shift. Some screw heads/solder blobs are in the middle of the date.
Another method was "D" for day, "N" for night and "T" for third. These were letters wandering around near the date.
There was also a "casting clock". Where Zero, or two dots, was 1st hour of shift. The pointer points to the hour of casting pour. It is thought that the pointer screw head could show what shift.
There are variations, change in methods, anomalies and factory screw ups which can cause numbers matching issues.
All these letters and numbers and symbols have been seen by us on our engines thru the years, but not all of us knew what some of them were for sure.
dbwr #1384405 11/13/2020 9:42 PM
I'll chalk it up to mystery we'll never solve.
1960 C20 Platform
dbwr #1384417 11/13/2020 10:50 PM
yep
dbwr #1384476 11/14/2020 4:35 AM
Sir Searchalot
Sir Searchalot
I think it will be solved by someone on here sooner or later.
