1 members (dunfire),
157
Mod | | | Forums66 Topics128,162 Posts1,056,941 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | I'm wondering if anyone is using a 90 ohm sending unit with a stock 30 ohm gauge? Does anyone make a box or board to do the conversion? Would a couple of resistors from Radio Shack do the trick?
Thanks | | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | If you have 90 ohm,s you cannot reduce it so you need to get correct sender...doc | | |
