1 members (2-Ton), 167 guests, and 3 robots.
Topics128,088
Posts1,056,114
Members48,434
#1383235 11/02/2020 11:53 PM
I made new inside door panels for the inside of my doors on my 53 3600 3/4 ton truck. First I made a cardboard template. Then transferred that onto a piece of 1/8 th inch hardboard. Made the holes for my window crank and door handle. Then cut a the black Naugahyde and wrapped the hardboard to it. First time I’ve done this.
I think it turned out nice. Just my opinion.
Very nice, Elmo
I did the same on/under my many Suburban windows.
Did you use waterproof hardboard - I did not, on my first try.
tclederman, I didn't know there was waterproof hardboard.
Elmo.
Is hardboard masonite?
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Nice. I did the same to my 49. I used 1/8" Tempered board.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
Mike Burns Yes hardboard is masonite.
Elmo
That turned out nice.
Elmo
Looks great! I did mine with ABS. Same with my rear doors, too!
[quote=MNSmith]Looks great! I did mine with ABS. Same with my rear doors, too![/quote
That looks great too!
Didn’t think to use ABS.
What size ,type of abs did you use .I need to either buy a headliner or make one thought if I can find the abs locally it might be worth a try
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
1/8" thick stuff, texture on one side, smooth on the other.
Looks good did it come in a 4x8 sheet. Looks like it fit nicely In the original bows
"The Journey"
Follow in the DITY
I used Formica! Worked great
Yes. 4x8 sheets.
WTH - your black Suburban has white interior?
Holy cow, for a minute I thought you posted a photo of MY door panels!
1951 Chevy Panel Truck
I believe what you actually meant to say was "WTH? Your primered, still doing metal work Suburban has a gray interior?"
Why, yes! Yes it does!
Shaaaaades of gray........
very nice
MN,
Is that 50 shades of (primer) gray?
Chris
yahoo thumbs_up chug
My apologies; the lighting (flash?) made it look white.
So the black primer is just temporary - you intend to actually paint the truck someday? My panel truck's feelings will be hurt ;-)
Lol! Sure! I've been telling myself that I'm going to paint it going on 8 years now??? Once I forget the pain of assembling it is when I'll start tearing it apart!! AND how much storage is required when everything is apart.
I guess context would help, huh? That would be me doing the painting and me not paying someone to do the painting. And now we understand the procrastination!!
Mnsmith,
It’s always more fun to drive then working on it anyway!
Chris
Truth!
I used 1/8" plywood. I bought batting and black vinyl from Walmart. I padded them a little to give them more of a contrast. They look great like others here in this post.
Awesome. Door panels are back ordered right now. I’ve tried from 3 places. I think I’ll make mine too! Glad I saw this! These look great
Moderated by  ndkid275, Phak1
