4 members (cmayna, klhansen, delwrench, TUTS 59), 83 guests, and 4 robots.
Topics128,190
Posts1,057,223
Members48,465
I need longer studs on my intake manifold to adapt to the carburetor I want to use. I need to put a spacer under the carburetor to clear the throttle linkage. I believe I need about 2 inch studs with 3/8 threads. Will the studs come out of the manifold? Are these available?
Thanks. Pete
Chevy Pete
Yes, the studs just screw into the manifold. Sometimes they're very stubborn, so use a good penetrating oil like KROIL or PB Blaster, some heat from a torch, and either a stud remover or tightly double-nut the studs and use a socket and a long handled ratchet or maybe an impact wrench to back them out. Dorman makes a good assortment of studs to choose from- - - -you'll probably find the thread in the manifold will be coarse, and the top will be a fine thread. For instance, 3/8-16 in the manifold, and 3/8-24 holding the carburetor on. Also try Fastenal for custom-length studs.
Thanks Jerry. I was able to get the studs out. Now on quest to find new ones.
Pete
Chevy Pete
As a last resort you could take a long 3/8-16 bolt, cut off the head, and cut a 3/8-24 thread onto the unthreaded portion of the shank. Then trim off both ends to get the thread lengths you need. I do that on a lathe, but if you're careful with an adjustable die the same thing could be done in a vise.
